TurboBaron Posted October 1, 2017 Posted October 1, 2017 Hey guys, hope you're all having a great weekend So I've moved from Virgin Media to BT and I'm having some issues with my setup. I've been able to set up the R1 to work with the BT Smart Hub, I understand there's no way to set the S/H to work in modem only mode, so I've simply disabled the wireless and ensured that my powerline adaptors are running through the R1. Here's where things get odd though - none of my devices now seem to like connecting wirelessly to the R1 The R1 is broadcasting a wireless signal, but when I connect my laptop to it I see the error message in the attached screenshot. Any suggestions on why this could be happening ? For the time being I've got round this by connecting up my Apple Time Capsule to the R1 and using the wireless signal it broadcasts, is this an acceptable setup to get the best out of the R1 ? Cheers guys Dom
bagsta69 Posted October 1, 2017 Posted October 1, 2017 Have you tried changing channel or ticking / unticking wifi workaround? I think that as long as everything is connected to the R1 (including apple thing as a wifi access point) you should have no problem with any of the features of the R1.
BENORMOUS Posted October 1, 2017 Posted October 1, 2017 Try using PSK2 as wireless security,my laptop won't work without it
Administrators Netduma Fraser Posted October 1, 2017 Administrators Posted October 1, 2017 Has your device properly connected to it? I notice my mac will have a blank wifi icon if it's tried to connect to something but failed. Does your device get an IP address when connected?
TurboBaron Posted October 4, 2017 Author Posted October 4, 2017 Have you tried changing channel or ticking / unticking wifi workaround? I think that as long as everything is connected to the R1 (including apple thing as a wifi access point) you should have no problem with any of the features of the R1. I had a faff with the different security protocols, and also with changing the channel. Don't think I tried wifi workaround but might have to give that a go.
bagsta69 Posted October 4, 2017 Posted October 4, 2017 If you are still struggling ill give you all my settings that I have ticked/unticked etc as I am with Bt infinity as well. On an overnight shift tonight but let me know if you want to try them.
TurboBaron Posted October 6, 2017 Author Posted October 6, 2017 If you are still struggling ill give you all my settings that I have ticked/unticked etc as I am with Bt infinity as well. On an overnight shift tonight but let me know if you want to try them. That'd be good if you could buddy, I'll PM you my email address if you want to screenshot them.
bagsta69 Posted October 6, 2017 Posted October 6, 2017 Ive had a drink its the weekend apparently. lol, tomorrow ill sort in fact ill pm you my mobile number and we. an and get you sorted buddy.
TurboBaron Posted November 12, 2017 Author Posted November 12, 2017 OK so having tinkered with some of my settings and "forgotten" and then reconnected to the R1 from my devices I seem to have been able to get the wifi working again. Not sure what I did precisely but I'm up and running again so let's leave it at that !
Administrators Netduma Fraser Posted November 12, 2017 Administrators Posted November 12, 2017 Great to hear that, keep us updated!
