Ltkveteran Posted June 27, 2017 Posted June 27, 2017 I just got my netduma router and going through initial set up I ran into problems. One, I had no wired connection but was able to connect via wifi. At that point I changed the ssid name and password. Went through the setup and still no Internet connection while wired, even though it shows everything is fine. At this point I did a hard reset and now the default password is no longer valid. Someone please assist me.
Ltkveteran Posted June 28, 2017 Author Posted June 28, 2017 Got it fixed. Now the problem is my download and upload speed is super low. I simply cannot do what I was doing before because of it. I was getting 200+/24 before and now on wired i get 50/.3 at the most. Netduma router is preventing full speeds. What can i do?
iAmMoDBoX Posted June 28, 2017 Posted June 28, 2017 http://forum.netduma.com/forum/14-knowledge-base/
Ltkveteran Posted June 28, 2017 Author Posted June 28, 2017 None of that fixes the issue. Thanks! I will be returning the product. Would much rather buy a $200 netgear router
iAmMoDBoX Posted June 28, 2017 Posted June 28, 2017 my download and upload speed is super low None of that fixes the issue. Thanks! I will be returning the product. Would much rather buy a $200 netgear router Then you clearly didn't read anything or even bother trying to set it up properly. http://support.netduma.com/en/support/solutions/articles/16000022366-why-is-my-connection-speed-lower- This link outlines exactly what to do, which is as simple as typing in your bandwidth and clicking "Yes" to let the router set itself up for you. If that's too much for you to do, then I can't help anymore than I already have.
Ltkveteran Posted June 28, 2017 Author Posted June 28, 2017 I did type in the bandwidth, it did not fix the issue. Still extremely low speeds
pollutionblues Posted June 28, 2017 Posted June 28, 2017 The links that MoD BoX suggested should enable you to achieve full speeds. Double check these settings and see if it fixes your issue Reactive Algorithm 100% anti-flood Share excess enabled Reset device prioritisation & apply Disable IPv6 in WAN, LAN & misc Disable deep packet in misc Enable turbo mode Ensure the ethernet cables you're using connecting the R1 to hub & R1 to PC are Cat5e+/can handle your speeds. Do a wired speed test from a PC
Administrators Netduma Fraser Posted June 28, 2017 Administrators Posted June 28, 2017 Hello, welcome to the forum! Please double check the settings/advice given above as that should give you full speeds through a wired PC.
Ltkveteran Posted June 30, 2017 Author Posted June 30, 2017 Hello, welcome to the forum! Please double check the settings/advice given above as that should give you full speeds through a wired PC. I have done all the above settings and double checked it. Wired speeds are super low, less than a 3rd of my actual speed. Did a hard reset of the router and followed the same steps again. Does not work for my ISP. Sorry! Would have loved the features of NetDuma but due to these issues, the features are not worth a speed trade off.
pollutionblues Posted June 30, 2017 Posted June 30, 2017 I have done all the above settings and double checked it. Wired speeds are super low, less than a 3rd of my actual speed. Did a hard reset of the router and followed the same steps again. Does not work for my ISP. Sorry! Would have loved the features of NetDuma but due to these issues, the features are not worth a speed trade off. The Netduma is compatible with all ISP's. Who is your ISP? Thanks
Administrators Netduma Fraser Posted June 30, 2017 Administrators Posted June 30, 2017 I have done all the above settings and double checked it. Wired speeds are super low, less than a 3rd of my actual speed. Did a hard reset of the router and followed the same steps again. Does not work for my ISP. Sorry! Would have loved the features of NetDuma but due to these issues, the features are not worth a speed trade off. Post in the 1 on 1 section: http://forum.netduma.com/forum/66-request-1-on-1/and I will have a look as there is no reason you shouldn't get full speeds. Please note I need around a days notice. Please read this first before making the post: http://forum.netduma.com/topic/11450-read-before-posting-a-1-on-1-request/
