DualShock 4 Controller Delay (Wired vs Bluetooth)
iAmMoDBoX
To make a fair test, he should just a use a v2 controller.
There's a significant difference between wired and wireless on v2
not debating if there is a difference, only pointing out the fact that its not a fair test.
In my book a fair test would be to use the same controller, then use accurate software/hardware to measure. and also to be preformed on the same tv/monitor, that has been warmed up for at least 30mins,
There are other things to consider, but for those few reasons above i would call it a void test.
Intresting
I've been following this guy channel for a while and his results on input lag been pretty accurate. His recent video shows the input lag between X1 and Ps4 Pro
