ugotstretched Posted June 3, 2017 Posted June 3, 2017 Is there a reason why my isp gives me 960 down and 880 up but with the duma im getting 180 over 100
iAmMoDBoX Posted June 3, 2017 Posted June 3, 2017 Is there a reason why my isp gives me 960 down and 880 up but with the duma im getting 180 over 100 http://support.netduma.com/support/solutions/articles/16000022366-why-is-my-connection-speed-lower-
PharmDawgg Posted June 4, 2017 Posted June 4, 2017 Everything is setup correct If that is the case then you may need to request a 1-on-1 here.
ugotstretched Posted June 4, 2017 Author Posted June 4, 2017 Unless xbox is just incosistent with speeds
PharmDawgg Posted June 4, 2017 Posted June 4, 2017 Try these steps to see if you can get your speeds up but if it doesn't work I would still recommend and 1-on-1. - Reactive Algorithm- 100% anti-flood- Share excess enabled- Reset device prioritisation & apply- Disable IPv6 in WAN, LAN & misc (Unless you know that you are on IPv6)- Disable deep packet in misc- Enable turbo mode - Enable super turbo mode - Ensure the ethernet cables you're using connecting the R1 to hub & R1 to PC are Cat5e+/can handle your speeds.- Do a wired speed test from a PC - more reliable than through a console.
Administrators Netduma Fraser Posted June 4, 2017 Administrators Posted June 4, 2017 Consoles can be inaccurate, what are you getting from a wired PC?
