ps21.850 Posted April 12, 2017 Posted April 12, 2017 everything works on my netduma except the host fitering page just keeps loading and never shows up
BIG__DOG Posted April 12, 2017 Posted April 12, 2017 are you using port forwarding or upnp, please not both! Do you have console in hyper traffic?........if you do and you are using port forwarding then here is the solution. unplug power to duma for roughly 10 seconds.....plug back in.......when it is ready, go to host filtering and disable it (make sure console is off at this point), start console and log into psn but not a game........turn on host filtering and start a game......you should play fine and when you finish gaming go to host filtering and disable it until you need to game again and follow the above instructions.
Administrators Netduma Fraser Posted April 12, 2017 Administrators Posted April 12, 2017 I've moved your post to General Support. Make sure you're using Google Chrome or Firefox to access the interface. Also use the default theme on the router.
