Mikes Posted January 18, 2017 Posted January 18, 2017 Hi .. I was having trouble opening my nat . But after some help on here I got it open via port forwarding.. but now my ping has gone up to 900 ! . Basically not playable .. is there something I've missed ?
Mikes Posted January 19, 2017 Author Posted January 19, 2017 Update on this .. it seems to be playing fine I'm getting good connections.. but I can't check the ping the user interface of the duma is so slow it won't load.. maybe something simple I'm over looking ?
slashformayor Posted January 19, 2017 Posted January 19, 2017 Update on this .. it seems to be playing fine I'm getting good connections.. but I can't check the ping the user interface of the duma is so slow it won't load.. maybe something simple I'm over looking ? http://forum.netduma.com/topic/19266-slow-gui-interface-the-solution-is-here/
Administrators Netduma Fraser Posted January 19, 2017 Administrators Posted January 19, 2017 Make sure you're using the default theme on the router not V2. Also double check this guide: http://support.netduma.com/support/solutions/articles/16000022397-why-can-t-i-ping-
Administrators Netduma Fraser Posted January 19, 2017 Administrators Posted January 19, 2017 Settings > Miscellaneous right at the bottom.
Mikes Posted January 19, 2017 Author Posted January 19, 2017 That seems to have done the trick .. turn off geofilter load up the game then turn geofilter on works perfectly so far
Netduma Staff Netduma Jack Posted January 20, 2017 Netduma Staff Posted January 20, 2017 That seems to have done the trick .. turn off geofilter load up the game then turn geofilter on works perfectly so far That's great to hear that trick works since the game connects to a "matchmaking" server upon being booted up; if the Geofilter blocks any of those sorts of background servers it can affect your NAT. Port forwarding can often fix it, but the best fix is simply turning it on once you're in the game. Glad it worked
Mikes Posted January 20, 2017 Author Posted January 20, 2017 Great stuff .. thanks again for all ur help
