Netduma R1 will not connect
Hey, welcome to the forum! So just to clarify, is the Netduma wired in to your modem? The password is case sensitive, so make sure it's inputted correctly. Make sure you connect your PC via ethernet and change the password manually; that should allow you to access the internet.
Edit:  To clarify, you can not access the GUI or you can not connect to the WIFI?  More info please
Just bought the netduma R1, trying to set it up, and my computer will not connect to it after I put the appropriate password in? Please help.
Hey Majik, just checking in to see if you managed to set your Netduma up? If you're still having issues feel free to let us know.
