kyroadie Posted December 31, 2016 Posted December 31, 2016 Hey guys. Weird one here for you. Current setup: Cable Modem---Netduma---ASUS Router---Everything else Xbox1S and tablet hardwired to Netduma; ASUS hardwired and handling all other wireless duties. Used to have X1S and tablet static along with ASUS Ran into some weird stuff including this issue of no longer seeing static ip devices in DM, so decided to factory reset. Reset fixed other issue, but this one still remains. If my devices are not using DHCP, they can't be seen by DM. So currently have X1S and tablet using DHCP and ASUS as still static. What that means is that I can't control amount of resources that ASUS (ie rest of network uses). I can't figure out what/why it changed all the sudden.... Your help is greatly appreciated. Thanks in advance.
fastfour71 Posted January 1, 2017 Posted January 1, 2017 I had the same issue. I had to change IP address and it worked.
Administrators Netduma Fraser Posted January 2, 2017 Administrators Posted January 2, 2017 If you put your Asus in AP mode then all devices connected to it will show up as individual devices on the device manager and you'll be able to control them as you see fit.
XSXS Posted January 2, 2017 Posted January 2, 2017 Is there a need or advantage of using static ips on the netduma? With other routers i prefer using static ips but how the netduma interface works i don't see a need to reserve ips
Administrators Netduma Fraser Posted January 3, 2017 Administrators Posted January 3, 2017 Well the obvious advantage is that the IP of the device will not change. The only real case that I seeing this being absolutely necessary just for pure ease of use is if you're manually port forwarding. If the IP changes then you'd have to manually port forward all over again which would be annoying.
XSXS Posted January 3, 2017 Posted January 3, 2017 Yeah i don't need or have to use Manual port forwarding to get open nat. Upnp is working for me at the moment. that is one cool feature that Asus has is that that you set rules, port forwarding, etc to the devices mac address so you never have to worry about that.
Administrators Netduma Fraser Posted January 4, 2017 Administrators Posted January 4, 2017 Yeah i don't need or have to use Manual port forwarding to get open nat. Upnp is working for me at the moment. that is one cool feature that Asus has is that that you set rules, port forwarding, etc to the devices mac address so you never have to worry about that. Yes I think that is something we should implement for DumaOS as it would make it a lot easier.
kyroadie Posted January 14, 2017 Author Posted January 14, 2017 I gave up and just reserved in DHCP. My router has been doing weird things so much that I didn't want to have to fight this as well. I also don't want to turn my $250+ ASUS router into an AP. It manages HDD and a printer that are working. The ASUS doesn't like not being the top dog though, I get a flashing yellow icon to remind me. haha I hope that the new OS will come soon. I struggle with the "clumsiness" of the current OS in regards to several things like profile changing/lack of current profile displayed. Also seems to lose saved settings often. Sometimes have to recreate Admin info. Settings get turned off and on that I previously configured, etc. Oh, just for clarity. In regards to static, I like to run a very small pool of IPs in DHCP and have a group of IPs reserved in the non-pool that I know are always there. For instance- static IPs between .05-.10 for PC, Xbox, Printer, etc then a pool from .11-.21 for the other devices that come and go...
ColonicBoom Posted January 14, 2017 Posted January 14, 2017 The ASUS doesn't like not being the top dog though, I get a flashing yellow icon to remind me. haha You can probably flash that Asus with Merlin firmware and then 'stealth mode' the lights. I did because it was annoyingly bright.
Administrators Netduma Fraser Posted January 15, 2017 Administrators Posted January 15, 2017 I gave up and just reserved in DHCP. My router has been doing weird things so much that I didn't want to have to fight this as well. I also don't want to turn my $250+ ASUS router into an AP. It manages HDD and a printer that are working. The ASUS doesn't like not being the top dog though, I get a flashing yellow icon to remind me. haha I hope that the new OS will come soon. I struggle with the "clumsiness" of the current OS in regards to several things like profile changing/lack of current profile displayed. Also seems to lose saved settings often. Sometimes have to recreate Admin info. Settings get turned off and on that I previously configured, etc. Oh, just for clarity. In regards to static, I like to run a very small pool of IPs in DHCP and have a group of IPs reserved in the non-pool that I know are always there. For instance- static IPs between .05-.10 for PC, Xbox, Printer, etc then a pool from .11-.21 for the other devices that come and go... Settings shouldn't change themselves. Have cookies enabled, have everything set up as you want then reboot from misc settings & should all save.
