Fsking Posted December 18, 2016 Posted December 18, 2016 so ever since i had port forwarding i had nat type open but till today it went back to moderate all day and i don't whats going on
Fsking Posted December 18, 2016 Author Posted December 18, 2016 omg i spend all day trying to see what happen till you told me about that ur life saver thank you can i know what it cased that ?
Fsking Posted December 18, 2016 Author Posted December 18, 2016 i don't understand it got my nat open then it got back to moderate again it really annoying me
Netduma Staff Netduma Crossy Posted December 18, 2016 Netduma Staff Posted December 18, 2016 so ever since i had port forwarding i had nat type open but till today it went back to moderate all day and i don't whats going on Read these instructions this to get an open NAT. The bullet points under 'Why is my NAT still not open?' may be worth you checking.
Fsking Posted December 18, 2016 Author Posted December 18, 2016 When I get home I'll give these a try and I have Xbox my port forwarding was name Xbox Start 3075 End. 3076 And my ip for the Xbox. and it was working fine
Fsking Posted December 18, 2016 Author Posted December 18, 2016 i tired everything my net type got worse its on strick now please help me
fuzzy clam Posted December 18, 2016 Posted December 18, 2016 Did you check the link out that Crossy posted ? At the bottom it tells you how to get an open NAT on XBOX You can also go to portforward.com and manually forward the required ports for the game your playing.
Fsking Posted December 18, 2016 Author Posted December 18, 2016 It's my Xbox over all have strict now And yes I did everything
Netduma Staff Netduma Crossy Posted December 18, 2016 Netduma Staff Posted December 18, 2016 It's my Xbox over all have strict now And yes I did everything Did you disable the GeoFilter before starting the game?
bagsta69 Posted December 18, 2016 Posted December 18, 2016 Under host filtering on the host filtering page your console will be listed, beneath it are 2 check boxes, show hosts and enabled. Untick enabled.
Fsking Posted December 18, 2016 Author Posted December 18, 2016 oh ya i also had done that few times nothing seems to be working
fuzzy clam Posted December 18, 2016 Posted December 18, 2016 It's my Xbox over all have strict now And yes I did everything Did you set a static IP on your XBOX before you manually forwarded the ports ?
Fsking Posted December 18, 2016 Author Posted December 18, 2016 I don't think so how would I do that When I had open net type all I did it port forwarding from my r1 and it worked but now it's not
fuzzy clam Posted December 18, 2016 Posted December 18, 2016 Go to portforward.com and it will tell you how to go about setting a static IP and give you the correct ports for the game your playing. Just be sure to go to settings on your duma and untick the box on the UPNP page and then click apply,do this first before going to portward.com
Fsking Posted December 18, 2016 Author Posted December 18, 2016 ones again its not only my game on moderate its my hole xbox
Fsking Posted December 19, 2016 Author Posted December 19, 2016 I been two days having this problem can anyone please help me more
Administrators Netduma Fraser Posted December 19, 2016 Administrators Posted December 19, 2016 NAT:Existing router/modem in modem mode or Netduma WAN IP from device manager in DMZ section.UPnP & port forwarding disabled on existing router/modem.UPnP OR port forwarding enabled on the netduma, not both.Un tick UPnP forwarding in miscellaneous settings. Boot up the console. Does console network settings say NAT Type 1/2 or open?
Fsking Posted December 19, 2016 Author Posted December 19, 2016 I got it fixed last night thank all of you for the help and now I have net type back to open I was resting everything but wasn't working at first but when I unplugged everything and plugged it back it start working again.
Administrators Netduma Fraser Posted December 20, 2016 Administrators Posted December 20, 2016 Great as your issue has been resolved I'll close this thread. Feel free to open another if needed
