ps4 pro help please
toby jugs
hi guys , am trying to set up my ps4 pro.
it says mod nat type?
 my duma can't find it and i cannot delete my old ps4 from the flower
cant set up service or hyper lane.
infact i can't do shite.
please help guys!
i got everything sorted apart from the nat type now.
have tried disabling the filter and resetting the ps4 but no joy yet
now my nat is strict.
i thought the duma automatically sorted an open nat??????????????????????????
Make sure you port forward or use UPnP, If you do then disable reboot the Duma enable them, Plus always power down the PS4 are pull the power cable out wait a minute and power back on
I had the same last night... Put your PS4 Pro in your Hyperlane and Port forward your PS4 Pro port 3074. Sorted!
i got type 2 from testing the ps4 connection I assume this is ok?
i'd like to get it open again as it was before on my old ps4 , which i didn't have to eff about with.
i don't understand the guide at all and there's many conflicting things on google aswell
Port forward 3074 UDP/TCP that solved mine
how do i do that raddy
Follow this guide mate. It didn't matter what I tried I could not get an open NAT on multiple consoles until I followed sims guide. Since I followed it, my 360, XBOX One & ps4 have all had an open NAT. It's crucial for pulling host on the older CoD titles so It's been a blessing.
This is a guide I did for blops 3 but I am sure the ports are pretty much the same. Ill have a google in a bit and find out which specific ones are for IW. For now you can just do this method for the port 3074 as Raddy mentioned.
http://forum.netduma.com/topic/15763-port-forward-for-blops3-on-ps4/
The sim video makes you rebuild database and all that which you do not need to do as your pro is brand new.
Simply forward the ports in the next post and you should be good.
Bags that's nailed it, I appreciate your time and effort and also everyone else's who have replied to this thread.
this issue is solved now , phew!
