My Connection Speed to start Share Play (PS4), is right on threshold.
lefteris.lydios
Yoy probably know the "Share Play" feature in PS4.
I've been trying to Share Play a game with a friend, but it seems that the speed I pay is right on thresehold for this feature.
In detail.
Here is the result with R1 hooked trying to start the app:
and the result with my old router.
These two extra bars in the yellow region can start Share Play.
I pay for 30/2.5 and there is nothing else I can do about it, but how can I resolve this issue with my Netduma hooked?
It is your upload the problem i think....when you try to "share" give 100% upload speed in your PS4.And your device must be with wired connection.
Are you using congestion control at the time so that your upload would be affected? Are you using hyper traffic as that shouldn't be used if you're going to be utilising a lot of bandwidth.
