Fsking Posted October 26, 2016 Posted October 26, 2016 Please someone help my net type says not open I went to device manager to view other router interface but it asked for password and user name !???
II N3MES1S II Posted October 26, 2016 Posted October 26, 2016 So you have your modem connected to netduma and then another router is connected to the netduma? What asked for a password, netduma or your other router?
Fsking Posted October 26, 2016 Author Posted October 26, 2016 I have dual bend connected to the r1 And each ttime I want go view interface it keep ask for password and user name on the r1?
Sir_smooch Posted October 26, 2016 Posted October 26, 2016 password is "netdumar1", unless you changed it sometime.
Administrators Netduma Fraser Posted October 27, 2016 Administrators Posted October 27, 2016 Hey, welcome to the forum! If when you click view other router interface and it asks you for a username and password that will be for the modem/router you connected the R1 to. The defaults are usually "admin" & "password" or something similar. You will need to search online for the model of that modem/router and check the default login for it. If that doesn't work then it's likely been set for you and your Internet Service Provider should have given you that information.
fuzzy clam Posted October 27, 2016 Posted October 27, 2016 I'm gonna go ahead and move this thread to general support.
