roozor Posted October 25, 2016 Posted October 25, 2016 Hi, Just got a new router and need help with config. Using my ISP'S provided Asus RT-N56UB1 I get 55mb every time on speed test using wifi. Using Netduma connected to it I only get 30mb. Thanks in advance.
PharmDawgg Posted October 25, 2016 Posted October 25, 2016 I'm not 100% sure of your complete setup but I would definitely use the R1 as your primary router and the Asus as an access point for Wi-Fi Wi-Fi purpose. If the Asus is a combo modem/router then I would set it up with the R1 in the Asus' DMZ.
roozor Posted October 25, 2016 Author Posted October 25, 2016 Hi Buck. It's bit of a strange setup. I have to use the Asus as it's Radio wave internet. This router have been reconfigured for my house. Getting 50mb down 20up and 11pings.
PharmDawgg Posted October 25, 2016 Posted October 25, 2016 Ok. I'll back out. Not familiar so it would be like the blind trying to lead the blind Got some pretty intelligent people in this forum. Someone should be able to assist.
Administrators Netduma Fraser Posted October 25, 2016 Administrators Posted October 25, 2016 Please try the following: Reactive Algorithm 100% anti-flood Share excess enabled Reset device prioritisation & apply Disable IPv6 in WAN, LAN & misc Disable deep packet in misc Ensure the ethernet cables you're using connecting the R1 to hub & R1 to PC are Cat5e+/can handle your speeds. Do a wired speed test from a PC Use a WiFi analyser and find the least congested channel and change to that.
roozor Posted October 25, 2016 Author Posted October 25, 2016 Hi Fraser.Thanks for the reply. Have changed all the settings and still no joy. I only get 36mb down on both wired and wireless through net duma r1. If I use the ASUS i get 55mb on both wired and wireless.The only thing I can't check is the Cat5e+ cable. Not sure what mine is. What does a normal cat5e cable top out at?
roozor Posted October 25, 2016 Author Posted October 25, 2016 Just checked. Cat6 from asus to net duma and Cat5e from net duma to my desktop
BIG__DOG Posted October 25, 2016 Posted October 25, 2016 have you enabled turbo mode and inputted your speeds into the netduma? if not go to device manager and put your speeds in there, but do not click auto config or it will undo all your settings, or, you can click auto and let it configure it for you but i do not let it!
Administrators Netduma Fraser Posted October 26, 2016 Administrators Posted October 26, 2016 Please try the above and if that does not work please make a post in the 1 on 1 section and I'll be happy to have a look.
