Small problem with NAT..
this has probably been answered on another thread, if so you can refer me to the thread and i apologize in advance, but i finally got my NAT type open on my xbox one, but when i load up Black Ops 3 it says Moderate, anything i should do different? also i have the geo filter disabled when i load the game and my xbox has a static IP address, also i have UPnP disabled, i port forwarded all ports for BO3
you should have upnp enabled, i dont use port forwarding for security and vulnerabilty ascociated with port forwarding and my nat is always open.
upnp is a smart forwarding system rather than manually assigning ports it does it for you.
Disable any UPnP/port forwarding on your ISP hub
R1 in DMZ of your ISP hub or ISP hub in modem mode
UPnP forwarding disabled in miscellaneous settings
Static IP on the Xbox itself or did you set it in DHCP lease?
