ColonicBoom Posted September 8, 2016 Posted September 8, 2016 A few companies do FTTH but only in a couple of areas of the UK. You'll have to Google it and then put your postcode in and see
MannyQ Posted September 22, 2016 Author Posted September 22, 2016 Ok update is I have cancelled Virgin completely they have not managed to rectify the issue and the customer service is a joke. SO new service starting on the 5th fingers crossed it will be a lot better One quick question the new provider is supplying me with 2 dedicated ip address said many gamers use this? How does it help and how do i set it up on the routers for the xbox and or playstation Ta
Administrators Netduma Fraser Posted September 23, 2016 Administrators Posted September 23, 2016 That's great to hear! I haven't heard of that actually. What I would assume is that you can set these statically on the hub itself and switch between them if necessary (e.g. if one got DDoSed). Then the duma would just do everything automatically. If you put the hub in modem mode then you would be able to set a static IP in the duma itself.
