Isp speed
Just recently changed from bt home hub to tp link and speed is more then what I pay for 20 up 75 down. On tp link at max is saying 30 up and 83 down. Would you put that in bandwidth control or what you pay for? Also the lines that are on Device management don't always look like they are connected to the Internet?
Max attainable is what the line could handle if it were un capped you must live very close to your cabinet.
Always put in your real world speeds after the cap and over heads, so after doing multiple speed sets to gain an average put the width into the duma.
Yes I do. shows up on tp link packet loss but doesn't show up on Duma Internet diagnostics. What about the lines on the device management?
Full line is Ethernet broken line is WiFi.
Sometimes the graphic is incorrect.
