TODDzillaInLA Posted August 4, 2016 Posted August 4, 2016 So first of all, I read all the tutorials, I think I have the r1 set up correctly, but at the moment I feel this r1 was a total waist of money. Not netdumas fault. Maybe i am missing something. Most Lobbies are completely laggy. I'm just getting melted which is not fun. If I'm the party host and we go into a game I just get straight connection f'ed. I can put 5 to 6 rounds into someone and they will have time to turn around and one shot me. If I play solo sometimes it's good and I run around like a cod God other times it feels like there is no hit detection. I have fios 150mb down 150mb up. I have the r1 connected straight to the wall with 2 Xbox ones connected to it. I also have the fios quantum gateway router connected to the r1 and all other devices including one more xbox one connected to that router. On tje r1 I have upnp enabled in both places on the r1, I have 3074 port forwarded for my XBOXONE-S 3075 port forwarded (3rd Xboxone connected to the verizon (now Frontier) router has port 3076 forwarded. ---------- Select Games / Services I have my Xbox one S and my Xbox elite in the game service section. I have Auto Ping Host Strict Mode Show Dormant Hosts Show Legend Checked, zoom factor at 2.5, filter by distance 3 clicks of the down arrow, ping assist 30ms, I live in downtown Los Angeles and I have the arrow in my area ---------- Anti flood Set bandwidth both have 150 and set to automatic. Reactive is clicked, download and upload cap both at 70%, Device Prioritisation shared access clicked, Hyper-Traffic both the s and the elite is there. ---------- VPN Enabled Devices When ever I go to the VPN section I get this notification "You are using the old VPN setting. It will still work but we recommend reconnecting to the VPN" How do I set this up correctly or disable it? ---------- Profiles I tried cod ultimate and it seems to backfire so I have it set to general gaming ---------- Devices I have FIOS_Quantum_Gateway, XBOXONES, XBOXONEELITE ---------- Miscellaneous Settings The only thing checked is Allow auto feedback(no personal data ever) to help improve the R1. Allow remote access to Netduma tech support. Enable upnp forwarding. Enable multicast snooping. Enable cookies. Turbo mode. ---------- Hopefully someone can help. Thanks in advanced
Administrators Netduma Fraser Posted August 4, 2016 Administrators Posted August 4, 2016 Hey, could you clarify your setup please like this: modem > R1 (consoles) > gateway (other devices) etc so I can visualise it easily. You should have UPnP OR port forwarding enabled. Not both. Disable UPnP in both places and port forward manually. It sounds like your radius is quite big, reduce this to ~1000km/650miles. Don't worry about VPN just make sure none of the devices on it are ticked. You can disable multicast & UPnP forwarding. Can you include a screenshot of your internet diagnosis results please.
Scrizzy Posted August 4, 2016 Posted August 4, 2016 Also, Black Ops 3 primarily uses port 3075 even with only one system active, so you can not just open port 3074 on one xbox, 3075 on another, and 3076 on a third. You will certainly have connectivity issues that way. I would make the adjustments that Fraser suggested, as well as port forwarding all appropriate ports to just one xbox one (3074, 3075, 4500, 3544, 500, 88, 80, 53) and play that way. If your connection fairs better, you can troubleshoot further from there with regard to figuring out what to do with the other two consoles. You should also play with your congestion sliders until you can achieve A ratings for bufferbloat on dslreports.com/speedtest No matter what, you will have issues trying to get all consoles to achieve open NAT's at the same time. Good luck. Report back
TODDzillaInLA Posted August 5, 2016 Author Posted August 5, 2016 Hey, could you clarify your setup please like this: Fios ONT > R1 > xb1-1 / xb1-2 / Fios Quantum gateway Modem/Router (g1100) then 1 more xbox and all phones tablets tv's and everything connected to g1100 You should have UPnP OR port forwarding enabled. Not both. Disable UPnP in both places and port forward manually. just did this, xb1-1 got all the port forwarding, any suggestions for the xb1-2? It sounds like your radius is quite big, reduce this to ~1000km/650miles. just changed it to 650 and 0ms Don't worry about VPN just make sure none of the devices on it are ticked. none are ticked You can disable multicast & UPnP forwarding. just did Can you include a screenshot of your internet diagnosis results please. is this ping diagnostics? PingPING 8.8.8.8 (8.8.8.8): 56 data bytes64 bytes from 8.8.8.8: seq=0 ttl=59 time=4.741 ms 64 bytes from 8.8.8.8: seq=1 ttl=59 time=5.211 ms 64 bytes from 8.8.8.8: seq=2 ttl=59 time=4.628 ms 64 bytes from 8.8.8.8: seq=3 ttl=59 time=5.063 ms 64 bytes from 8.8.8.8: seq=4 ttl=59 time=5.127 ms 64 bytes from 8.8.8.8: seq=5 ttl=59 time=5.415 ms 64 bytes from 8.8.8.8: seq=6 ttl=59 time=2.973 ms 64 bytes from 8.8.8.8: seq=7 ttl=59 time=3.359 ms 64 bytes from 8.8.8.8: seq=8 ttl=59 time=6.296 ms 64 bytes from 8.8.8.8: seq=9 ttl=59 time=3.824 ms 64 bytes from 8.8.8.8: seq=10 ttl=59 time=4.128 ms 64 bytes from 8.8.8.8: seq=11 ttl=59 time=4.494 ms 64 bytes from 8.8.8.8: seq=12 ttl=59 time=10.313 ms 64 bytes from 8.8.8.8: seq=13 ttl=59 time=5.013 ms 64 bytes from 8.8.8.8: seq=14 ttl=59 time=5.716 ms 64 bytes from 8.8.8.8: seq=15 ttl=59 time=3.855 ms 64 bytes from 8.8.8.8: seq=16 ttl=59 time=3.649 ms 64 bytes from 8.8.8.8: seq=17 ttl=59 time=3.644 ms 64 bytes from 8.8.8.8: seq=18 ttl=59 time=4.366 ms 64 bytes from 8.8.8.8: seq=19 ttl=59 time=4.703 ms --- 8.8.8.8 ping statistics --- 20 packets transmitted, 20 packets received, 0% packet loss round-trip min/avg/max = 2.973/4.825/10.313 ms Tracetraceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 38 byte packets 1 173.60.123.1 1.748 ms 2.197 ms 2.211 ms 2 172.102.101.118 6.855 ms 7.568 ms 8.978 ms 3 74.40.3.37 4.097 ms 5.259 ms 5.032 ms 4 74.40.3.198 3.423 ms 5.573 ms 4.272 ms 5 74.40.26.254 5.167 ms 7.625 ms 5.039 ms 6 209.85.245.99 4.555 ms 216.239.59.205 4.873 ms 4.970 ms 7 209.85.255.193 5.935 ms 216.239.62.107 4.209 ms 209.85.249.223 5.019 ms 8 8.8.8.8 4.559 ms 4.505 ms 4.791 ms here is the results from dsl reports, i have fios 150/150 when i had the g1100 connected first i would get over 150mb connection results and now with the r1 im getting around 100 over and under. <a href="http://www.dslreports.com/speedtest/4626834"> <img src="http://www.dslreports.com/speedtest/4626834.png"></a> thanks for the help guys
Administrators Netduma Fraser Posted August 5, 2016 Administrators Posted August 5, 2016 Thanks for the information. Sounds like everything is connected to the duma which is great, everything needs to be behind it in order for congestion control to work correctly. For the second console you will need to port forward as Scrizzy advised, this link explains it too https://support.activision.com/articles/en_US/FAQ/Ports-Used-for-Call-of-Duty-Games You've got a great ping with a little bit of jitter/spikes. It's not terrible but not ideal either. For your speeds: Reactive Algorithm 100% anti-flood Share excess enabled Reset device prioritisation & apply Disable IPv6 in WAN, LAN & misc Disable deep packet in misc Enable turbo mode Ensure the ethernet cables you're using connecting the R1 to hub & R1 to PC are Cat5e+/can handle your speeds. Do a wired speed test from a PC
TODDzillaInLA Posted August 10, 2016 Author Posted August 10, 2016 sorry i took so long to reply back, everything is awesome now when playing solo, check out my clans twitter page, i have a couple videos and screens shots up. i flew though a bunch of challenges with the netduma that i was struggling with before having it, i just unlocked 100% of all multiplayer challenges Twitter: @OWUH_Gaming Instagram: @OWUH_Gaming www.offwithurhead.com the only problem im having is trying to get open nat on both systems and when ever playing in a party or more then a group of 3 game sucks, no hit detection still laggy
Administrators Netduma Fraser Posted August 11, 2016 Administrators Posted August 11, 2016 Great to hear that! UPnP disabled, all port forwarding done including XBL and game ports doing 3074/5? Also make sure to add your friends to your allow list http://support.netduma.com/support/solutions/articles/16000022357--with-the-geo-filter-how-do-i-play-with-friends-
TODDzillaInLA Posted August 12, 2016 Author Posted August 12, 2016 the adding friends is a little hard the map kinda sucks when you zoom in all the text is on top and kinda blocks everything. i just notice with upnp disable only one xbox is open the 2nd xbox in settings/network is moderate but on black ops cause i have 3075 forwarded on that xbox its open on the BO3 screen and the first xbox with all the port forwarding rules in settings/network its oopen but this one has 3074 forwarded and its moderate on the bo3 screen. kinda driving me nutz
Administrators Netduma Fraser Posted August 12, 2016 Administrators Posted August 12, 2016 Are you referring to the legend as text? Un tick the show legend box so you can see more. Strange, I don't think this would work but enable UPnP disable all port forwarding except for 3075 for the second console. This will reduce the chance of port conflicts but may help opening the NAT if UPnP doesn't try to open it
TODDzillaInLA Posted August 15, 2016 Author Posted August 15, 2016 Deleting all the port forwarding and enabling upnp allows only one game to be open for nat on BO3 but now on the console setting /network nat type is moderate
Administrators Netduma Fraser Posted August 15, 2016 Administrators Posted August 15, 2016 I'm quite confused on whats happening with your setup. How can the game be open but not the console? Post in the 1 on 1 section and I'll take a look.
