iorkel Posted May 19, 2016 Posted May 19, 2016 Hi, I just got my NetDuma 3 weeks ago, I've been having some problems with it, I have a 200MB symmetric connection, when I got the router I asked my ISP to put their modem in bridge mode, the problem was that in that way the top speed I was getting was 20MB download 3MB upload. I asked them to put it in the regular way and the max speed I get via ethernet is 115MB download and 50MB upload, via wifi 40MB symmetric, I have followed all the tutorials, seen a lot of videos form Netduma and in youtube, made all the recommended changes, but... Still have the problem, when I bought the Netduma I had the idea by posts and videos that you could reach high speeds with the router...
Netduma Staff Netduma Crossy Posted May 19, 2016 Netduma Staff Posted May 19, 2016 Are you on the latest version (1.03.6)?
ColonicBoom Posted May 19, 2016 Posted May 19, 2016 You can, I get 157/10 with mine (which is the max I pay for) - over wifi. Post some pics of your settings and details of your setup we'll have a look
iorkel Posted May 19, 2016 Author Posted May 19, 2016 Are you on the latest version (1.03.6)? Yes, that is the version I got with it. Thanks for your help and time.
iorkel Posted May 19, 2016 Author Posted May 19, 2016 You can, I get 157/10 with mine (which is the max I pay for) - over wifi. Post some pics of your settings and details of your setup we'll have a look I'll post them as soon as I get home, thanks for your help and time.
Netduma Staff Netduma Crossy Posted May 19, 2016 Netduma Staff Posted May 19, 2016 Yes, that is the version I got with it. Thanks for your help and time. Have you followed this guide for speeds?
iorkel Posted May 20, 2016 Author Posted May 20, 2016 Have you followed this guide for speeds? Yes, already followed it...
iorkel Posted May 20, 2016 Author Posted May 20, 2016 You can, I get 157/10 with mine (which is the max I pay for) - over wifi. Post some pics of your settings and details of your setup we'll have a look Done
Administrators Netduma Fraser Posted May 20, 2016 Administrators Posted May 20, 2016 Hey, welcome to the forum! Please try the following: Reactive Algorithm 100% anti-flood Share excess enabled Reset device prioritisation & apply Disable IPv6 in WAN, LAN & misc Disable deep packet in misc Enable turbo mode Ensure the ethernet cables you're using connecting the R1 to hub & R1 to PC are Cat5e+/can handle your speeds. Do a wired speed test from a PC
