Scythe Posted May 5, 2016 Posted May 5, 2016 Does anybody use Youview BT tv through the R1. I plug the Youview box straight to the hub5 its fine. Put it through the R1 and it fails to stream.
ByMgRs Posted May 5, 2016 Posted May 5, 2016 I have the same problem, it is caused by the BT box using some sort of port through the H5 to validate you have a BT TV package!
Zennon Posted May 5, 2016 Posted May 5, 2016 Cheers. I am round at Scythes house now and running ping plotter with a direct connection to the youview box with no impact to pings or jitter. I didn't think it would as 1080p only uses 7mb.
Scythe Posted May 8, 2016 Author Posted May 8, 2016 Cheers for the reply ByMyRs Cheers Zennon for the guidence I have checked ping plotter three times now while youview box is streaming and its still having no impact to pings or jitter.
Administrators Netduma Fraser Posted May 9, 2016 Administrators Posted May 9, 2016 Cheers for the reply ByMyRs Cheers Zennon for the guidence I have checked ping plotter three times now while youview box is streaming and its still having impact to pings or jitter. Thats great so that means you should be fine leaving it as the only thing connected to the BT box & still be able to use the congestion control
