PS4 Nameless Device? Help.
Rename it from device manager click on where it says nameless and input PS4.
The advice above is solid.  You can rename the devices from in the DEVICE MANAGER tab.
If you don't have your PS4 labeled, do you also have 'NAMELESS DEVICE' in the Hyper Lane?  Because you are missing out on a key feature if not.
Where is located the "Hyper Lane"?
Great as your issue has been resolved I'll close this thread. Feel free to open another if needed :)
