bagsta69 Posted May 1, 2016 Posted May 1, 2016 If you have wifi workaround ticked, try unticking it I think, I'm not sure you can download free stuff that scan channels and tell you what the least congested is. A quick Google should help you.
bagsta69 Posted May 1, 2016 Posted May 1, 2016 Are you just using the R1 or do you have another router in the chain as well.
bagsta69 Posted May 1, 2016 Posted May 1, 2016 Ok, read this thread and make sure you are on the latest version of software. Somebody else might be able to help if you start a thread about the specific problem of wifi drop outs. Remember to include ALL the information asked for here http://forum.netduma.com/topic/11776-please-read-before-posting-a-support-thread/
Monzo Posted May 1, 2016 Author Posted May 1, 2016 ok. Again, thank you for all of your help. I really appreciate it.
Administrators Netduma Fraser Posted May 2, 2016 Administrators Posted May 2, 2016 You mentioned you changed settings and then you started experiencing issues, do you remember what you changed? With wifi you've already been advised to disable wifi work around which should help. Disable wifi on ISP hub as well.
