konvict Posted April 5, 2015 Posted April 5, 2015 Hi, I've been having slow speeds with my Netduma since day 1 on newsgroups. When I had my BT HH3 in SABNZB I got DL speeds of 5.2 Mbps, with the Netduma I get 3.8Mbps maximum. I have tried every setting I can think of in my control panel to sort this, IPV6 is not set, share excess is set in congestion control, all devices have priority 7, download/upload cap is 100% and I've also tried to change the channel of the Wifi but it is still the same speed. I've tested it wired into the Netduma and I get my full DL speed of 5.2Mbps, however wifi is always 3.8Mbps maximum. Any ideas on how to fix this?
Guest Netduma_Iain Posted April 5, 2015 Posted April 5, 2015 If wired is getting full speed. Then its completely to do with interference either physical things in the way or other routers in the vicinity. There is a wifi channel checker program that some users have suggested using. I don't know it of the top of my head but hopefully Zennon or someone will post here later
konvict Posted April 5, 2015 Author Posted April 5, 2015 But if I put my HH3 back in place my speeds are once again 5.2Mbps over wireless.
Zennon Posted April 5, 2015 Posted April 5, 2015 Wifi analyzer for android Shows you congested channels so you can change channel.https://play.google.com/store/apps/details?id=com.farproc.wifi.analyzer&hl=en_GB Is the duma the only machine handing out wifi in the house? is the HH3 wifi off when the duma is on? If the HH3 is off have you tried matching the same channel that the HH3 uses?
Dirty Dog Posted April 5, 2015 Posted April 5, 2015 Have you disabled the wifi on HH3 when testing Duma wifi? Having both on at the same time can cause unwanted issues.
konvict Posted April 5, 2015 Author Posted April 5, 2015 I have an iPhone. HH3 is off and only the R1 is serving wifi to the house. My wifi channel is the same (1) as it was in the HH3.
Zennon Posted April 5, 2015 Posted April 5, 2015 If you would like to check...Iphone http://moreinfo.thebigboss.org/moreinfo/depiction.php?file=wifiexplorerDp Windowshttp://www.inssider.com/It could be that the duma is picking up more neighbours on channel 1 that the HH3 does just a thought.
konvict Posted April 5, 2015 Author Posted April 5, 2015 I just tried inssider and there were 6+ overlaps on channel 1. Moved to channel 5 with only three overlaps so I'll try it again later. Thanks for the help.
