Andi Halbig Posted April 25, 2016 Posted April 25, 2016 hey guys, i got my geo filter set to 40 ms and my range to 1124km but i always connect to lobbys where i have an average ping of 60 - 90 ms. Does anyone know how to fix this? i play on the xbox one bo3
Dillinger Posted April 25, 2016 Posted April 25, 2016 So you have Ping Assist outside of your Geo Filter set to 40ms, and you have a Geo Filter range of 1124KM, where you will accept any host unless they have been Temp Banned or you rated a P2P player low? Are the lobbies INSIDE your Geo Filter when this happens? If so, the router is working exactly as intended. Also can you define: FIX? Do you only want to connect to games of 40ms or less? Or do you always want to just connect to hosts inside the Geo Filter? Please elaborate.
Andi Halbig Posted April 25, 2016 Author Posted April 25, 2016 i just want to connect to games where my ping is 40ms or lower, sorry for bad english but im german
Dillinger Posted April 25, 2016 Posted April 25, 2016 Okay, in that case you settings are a bit off, but the router is working correctly. If you just want to join 40ms or LESS games, load the COD Ultimate profile, or do the following. Place your home in the middle of the ocean with a very tiny geo filter. Make your Ping Assist meter read 40ms (if you want 40ms to be the high end of acceptable, 50 if 50ms is acceptable and etc). NOTE: This will be based on your base ping, so if your base ping is 40, you may not find many games. Wait 2 mins for the setting to take hold. Join Match. This may take up to a couple of minutes to find the first lobby. When it does join, you should be getting games OUTSIDE of your Geo Filter, but UNDER the 40ms set by your Ping Assist meter. Does that make sense?
reyster194 Posted April 25, 2016 Posted April 25, 2016 So you have Ping Assist outside of your Geo Filter set to 40ms, and you have a Geo Filter range of 1124KM, where you will accept any host unless they have been Temp Banned or you rated a P2P player low? Are the lobbies INSIDE your Geo Filter when this happens? If so, the router is working exactly as intended. Also can you define: FIX? Do you only want to connect to games of 40ms or less? Or do you always want to just connect to hosts inside the Geo Filter? Please elaborate. I thought that when you set your ping assist, it was set within your geo filter and filter range and not on the outside of geo filter. Sorry, I'm new to this Netduma router.
ColonicBoom Posted April 25, 2016 Posted April 25, 2016 I thought that when you set your ping assist, it was set within your geo filter and filter range and not on the outside of geo filter. Sorry, I'm new to this Netduma router. Hi Reyster, No need to apologise. Dillinger is right, it sounds like it's working perfectly but you have slightly misunderstood how it works (I did exactly the same at first). The ping assist will allow exceptions to the geofilter, so you'll connect to games within the geofilter OR games with a ping at or below the 'ping assist' value. If you only want games within your geofilter you need to set ping assist to '0'. If you only want games below a certain ping then you need to do what Dillinger said and put the geofilter in the ocean and pick a 'ping assist' value based on your 'base ping +10ms to 20ms', then the host will only be picked by the 'ping assist' value. If you find you're not getting games then you should either increase the geo circle or the base ping (or both if you are using both).
Administrators Netduma Fraser Posted April 27, 2016 Administrators Posted April 27, 2016 Hey welcome to the forum! Dillinger & Colonic has provided you with great information which should get you sorted. Feel free to ask any further questions if you need help
