todd0007 Posted April 2, 2016 Posted April 2, 2016 Hi. Just received my NedDuma R1 router and I'm not sure if I should open it or return it. My dilemma is I live in a 1800 sq foot split level (2 1/2 floors) home. The router would be located on the bottom floor of the house, pretty close to center. Does anyone know if it will cover the outside edges 2 1/2 floors up? If I read the terms correctly if I power it up to see then I can't return it. Thanks for any help. I only have a few more days to return it.
major masingil Posted April 3, 2016 Posted April 3, 2016 Mine works from the badement to the attic 3 floors plus outside in the yard. You should be fine.
Administrators Netduma Fraser Posted April 4, 2016 Administrators Posted April 4, 2016 Hey, welcome to the forum! I live in a fairly spacious 2 storey house and the signal reaches the whole house and even outside in the garden. You should be okay.
fuzzy clam Posted April 6, 2016 Posted April 6, 2016 Agreed... the WIFI on the duma is IMO very strong
