Problems with loading congestion control and host filtering
Dear Sir or Madam,
I really need your help, after I upgrade to 1.03.6g  version. I cannot load the pages of congestion control and host filtering. I just purchased the router for one month. I really need your help. Thank you so much
Hey, welcome to the forum :)
If you reboot the router does this problem solve? If not, can you right click the page while it is loading, then click 'Inspect Element', then 'Console' and see if there are any errors in red. If there are can you screen shot them and post them here.
Have you turned off the router for 5 minutes waiting for the ram to deplete it's energy?
Have you tried using firefox or chrome?
After I did other wise factory reset from settings > misc. ... it still has the same problems... so what should I do now?
Iain will probably need to access your router and see what the issue is. Will show him when he is feeling better.
I really need your help, so how can I let you guys access my router?
Make sure the Netduma is in the DMZ of your other router (if you are connected to a modem don't worry about that) and ensure that allow remote support is enabled in settings >> miscellaneous.
yes I already set up likes you said...
Ok, then they should be able to access your router when they try to take a look :)
  • 2 weeks later...
Got Iain to have a look, we can't see anything that could be causing it.
Could you please try on a mobile device or another device and see if it works.
If so it looks like it maybe a firewall on your PC or similar causing it.
I don't know I try to turn off complete firewall on my computer. I try to use mobile device is the same thing happens.
Do you have any adblock in your browser or anything like that?
If you want to post in the request section I can take a look.
