Knomax Posted March 2, 2016 Posted March 2, 2016 Hello.... I use a TP-Link TD-W9980 as modem router and R1....my ps3 has NAT 2. I want ps3 to connect to R1-->TD-W9980 via PPPoe connection. So i set up my TD-W9980 as this guide to "Bridge" mode...(VDSL Modem) Then i put in R1 "WAN" page my PPPoE Username and Password..."WAN IP" Disabled,"WAN MAC Address" Disabled,"WAN VLAN" Disabled,"IPv6" Disabled,"MTU" Disabled and put 1492 as mtu. So what i am doing wrong????Because i have no internet at all!!! My purpose is to connect my ps3 via PPPoE to have nat type 1. Please help.
Knomax Posted March 2, 2016 Author Posted March 2, 2016 UPDATE* I can take NAT TYPE 1 when i connect ps3 to Tp-link....so TP-link settings is ok as "Bridge". But when i connect ps3 via wireless with R1 fails to connect ...so something with settings in R1 going wrong.
Netduma Staff Netduma Crossy Posted March 2, 2016 Netduma Staff Posted March 2, 2016 Why do you want a NAT type 1? NAT type 2 is what it is suppose to be.
Knomax Posted March 3, 2016 Author Posted March 3, 2016 I suppose if it has any more benefits....so whats wrong with my settings in R1 and fails to get ip?
Administrators Netduma Fraser Posted March 3, 2016 Administrators Posted March 3, 2016 There would really be no discernable difference between NAT 1/NAT 2 in that situation. So if it is creating an issue I wouldn't bother. However try: Power off both your hub and your Netduma. Now connect port 1 of the Duma into any other port on the other hub. Power up the hub and after a minute, power up the Netduma.
Knomax Posted March 4, 2016 Author Posted March 4, 2016 I try Fraser ....nothing change...Google Chrome says..."ERR_ADDRESS_UNREACHABLE" when i try to open the hub page....and ps3 can't get IP.
Netduma Staff Netduma Crossy Posted March 4, 2016 Netduma Staff Posted March 4, 2016 I try Fraser ....nothing change...Google Chrome says..."ERR_ADDRESS_UNREACHABLE" when i try to open the hub page....and ps3 can't get IP. Can you just go back to the old setup when you had NAT type 2 if that worked?
Knomax Posted March 5, 2016 Author Posted March 5, 2016 I can only open my TP-Link modem/router page in my browser only if i connect it directly with my pc...etc...wifi my pc and wireless connection with TP-link....if i connect my pc wireless with R1 and try to open TP-Link configuration page it doesn't open it. And ps3 when i make a PPPoE connection directly with TP-Link everything is ok...it get's IP and so on.......when i try to connect ps3 with PPPoE connection with R1 it fails to get IP....thats my problem....i can't use R1 in gaming if i connect ps3 directly with TP-Link...i want to connect it via R1. In old set up with TP-Link use as modem router not in brigde mode everything was ok.
Administrators Netduma Fraser Posted March 9, 2016 Administrators Posted March 9, 2016 Sorry for the late reply. I would go back to the old setup if that was working fine, this new setup won't give you any advantages. If you really want to try it this way, I would make sure you're inputting the correct PPPoE info into the duma then power cycle modem and R1, see if that resolves it.
