Chiver2007 Posted February 28, 2016 Posted February 28, 2016 Hello all, yes I know with the netduma I probably wont be able to get a full 1gb speeds, but what I want to know is whenever I try to update the values I enter for download and upload, it then asks me if I want to allow the router to auto-setup which I click YES. I then go back and check on the device manager and it still says the DEFAULT 100/10 speeds. It even did this after a factory reset, it will not save my speeds that I input in the values. I am running the newest firmware.
ImSallad Posted February 28, 2016 Posted February 28, 2016 Have you enables cookies in miscellaneous? also do you have super turbo mode enabled (same section)
Chiver2007 Posted February 28, 2016 Author Posted February 28, 2016 On another note, does having the router "automatically" set everything up, pretty reliable? When I had the router do that, it kept the same download/upload speeds I entered.
ImSallad Posted February 28, 2016 Posted February 28, 2016 what do you mean by set everything up? as is when you put the internet speeds in let it sort your speeds itself or let all the settings for the whole router be set up automatically?
Chiver2007 Posted February 28, 2016 Author Posted February 28, 2016 Yes, when I did a factory reset and entered my download/upload speeds in asked if I wanted to have the router automatically configure itself, so I selected yes.
F3arless27 Posted February 28, 2016 Posted February 28, 2016 i have 1 gig and 50 up and can't get close to that speed have sliders at 100 on upload and download and also have super turbo mode enabled only getting around 90 down and 50 up something is wrong in my settings
ggkthx Posted February 28, 2016 Posted February 28, 2016 999 is the maximum value you can input. Router doesn't recognise 1000.
Administrators Netduma Fraser Posted March 2, 2016 Administrators Posted March 2, 2016 If you have to put 999 in and allow auto set up to set up for your speeds whatever you get is likely the max you can get. Theoretically we can achieve ~900mbps in a perfect setting. Real world this may not always be possible. Ensure you're using an ethernet cable between your PC and duma that can handle those speeds Cat6e and above.
e38BimmerFN Posted March 2, 2016 Posted March 2, 2016 To get best performances on for actual 1000Mb and beyond, you need 10Gb supporting connection rate devices. Unfortunately there isn't much if any currently for consumer class 10Gb HW. 10Gb is mostly kept to big business and enterprise class environments. I presume that maybe in the next 5 years we may see that change. There's been talk here and there of it in other forums. Same thing happened when we graduated from 100Mb to 1000Mb years back. Current consumer HW wont do much passed 900Mb.
