blakeyb1 Posted January 27, 2016 Posted January 27, 2016 I know exactly what the problem is if you're on BT you have to set the homehub in a DMZ with ports open so the ps4 goes nat type 2 aka open, It's really easy if you need any more help just drop a message on here and i'll run you through it
STACEY85 Posted January 27, 2016 Author Posted January 27, 2016 thanks for your reply. I've put it in DMZ and the internet connection test on PS4 says nat type 2 (I thought type 2 was moderate). On the multiplayer home screen on black ops 3 it say : NAT type moderate. Sony recommends a moderate nat type for security reasons. What's best for gaming? I'm a little confused, everyone tells me "nat" should be open and that type 1 is open.
sncjez Posted January 27, 2016 Posted January 27, 2016 I just reboot the netduma then do a test connection in ps4 network settings works every time to get an open nat
blakeyb1 Posted January 27, 2016 Posted January 27, 2016 Open if you like hosting games and p2p games is better since everybody can connect nat type 2 is both on the ps4 the speedtest on the console is all kinds of messed up, have you opened your ports on the homehub aswell as the DMZ, i think the ports are mainly 3074 and xbox live/ps3/ps4 on the router (they're already pre-added on the homehub you just need to select them) asoon as they're open you should be on open, but if that doesn't work open the same ports on the netduma just incase. Moderate is fine though you can still get great gameplays on it.
blakeyb1 Posted January 27, 2016 Posted January 27, 2016 https://gyazo.com/9a017d30131e5cb3e1893f47d1658dceThat's what your router page should look like after doing everything
STACEY85 Posted January 27, 2016 Author Posted January 27, 2016 thank you - I'll try all those ideas This set up process is certainly giving me a little knowledge about connection
blakeyb1 Posted January 27, 2016 Posted January 27, 2016 I'll be around so don't be afraid to post to ask again for help.
STACEY85 Posted January 27, 2016 Author Posted January 27, 2016 Port forwarding BT HH5 I found the xbox live on "game or application" but can't find PS4 in the drop-down box, only PS3
STACEY85 Posted January 27, 2016 Author Posted January 27, 2016 Blakey, did you find PS4 in your hub manager drop down box on your BT hub or did you manually enter it?
Administrators Netduma Iain Posted February 5, 2016 Administrators Posted February 5, 2016 Hi Stacey, Welcome to the forum. Sorry for the late reply, hope you got the Wi-Fi installation sorted
