ltr7 Posted January 20, 2016 Posted January 20, 2016 I'm trying to install a Linksys wrt1900ac behind the R1 but I'm not having any luck. If anyone could help out I would appreciate it.
Netduma Staff Netduma Crossy Posted January 20, 2016 Netduma Staff Posted January 20, 2016 Would you be able to explain how your physical setup is and where you want the Linksy in relation to that?
PharmDawgg Posted January 20, 2016 Posted January 20, 2016 You will probably have to disable the dhcp server that way it will not give out ip addresses. And edit you're IP address for the Linksys router to something that is not the same as your R1 router. Like 192.168.88.2. Also use ethernet cable and connect LAN to LAN. Turn wireless off on the R1.
e38BimmerFN Posted January 20, 2016 Posted January 20, 2016 New method 8/2015 : Change the routers IP address from 192.168.1.1 to a Static LAN IP Address (Main router LAN IP Address range 192.168.#.19 or 90) and set AC1900 Internet Setting to Bridge Mode. Then connect the AC1900 WAN to the primary router's LAN. To connect to the APs web page, use the new static IP address that was changed too. i.e. 192.168.#.19 or .90 Connectivity => Internet Settings => IPv4 => Bridge Mode Set a IP address on the WRT router. I use 192.168.#.19 Input the gateway IP address (main host routers ip address) Subnet mask should be the same and the main host routers, usually 255.255.255.0 DNS can be the main host routers as well. Save settings and power OFF. Connecting that main host routers LAN port to the WRTs WAN port should be all thats needed. Power ON the WRT. Its how I have mine set up. I'm trying to install a Linksys wrt1900ac behind the R1 but I'm not having any luck. If anyone could help out I would appreciate it.
ltr7 Posted January 20, 2016 Author Posted January 20, 2016 Got it sorted, thanks for the quick help!!!
PharmDawgg Posted January 20, 2016 Posted January 20, 2016 Since it is sorted I will close this post.
