Welshy Posted January 13, 2016 Posted January 13, 2016 Hi all, I live in the UK using the Xbox and have set my home location over Germany/Belgium only, ping assist on zero with strict enabled but the geo filter does not detect any dedi servers and I can't get into any lobbiies. I have both the Xbox/PS4 and use the exact same settings on the PS4 and have no problems finding a server and getting into a game. Any ideas whats going on? When I disable the geo filter on the xbox I get into lobbies with US folks and I live in the UK?
Administrators Netduma Fraser Posted January 13, 2016 Administrators Posted January 13, 2016 Does anything appear on the Geo-filter when using your Xbox?
Welshy Posted January 13, 2016 Author Posted January 13, 2016 First of all i.e during downloading/checking files it does in my geo filter range then it only shows locked or caution signs in UK.
talbyfish Posted January 13, 2016 Posted January 13, 2016 on xbox one the uk servers show up in USA. I do what you are doing now to get me in p2p games as the servers dont agree with me. Either turn strick off before searching or move ping assist to your base ping. I get 11ms to UK servers which show on the map as USA.
talbyfish Posted January 13, 2016 Posted January 13, 2016 try team deathmatch with your settings as they are. It will find a game and you will be boss... you can force host this way.
Welshy Posted January 13, 2016 Author Posted January 13, 2016 on xbox one the uk servers show up in USA. I do what you are doing now to get me in p2p games as the servers dont agree with me. Either turn strick off before searching or move ping assist to your base ping. I get 11ms to UK servers which show on the map as USA. So keep my geo filter over Germany/Belgium and turn strict off or move my ping right?
Welshy Posted January 13, 2016 Author Posted January 13, 2016 Pretty cxxp m8. Tried both with strict off and then moving my ping and no good I''m split second behind. Any suggestion I would be grateful but will have to reply back to you tomorrow pm as I'm off for my ZZZZZZZZ
mark Posted January 13, 2016 Posted January 13, 2016 I'm on Xbox I have my radius covering uk and Ireland 800km strict on ping assist 0 there's an Irish dedi that's been playing pretty well for me
Administrators Netduma Fraser Posted January 14, 2016 Administrators Posted January 14, 2016 If you're in the UK would recommend 1000km radius, strict on and PA at 0. Ensure you have auto&bleeding edge cloud ticked and applied in settings > miscellaneous and you should get games
Welshy Posted January 14, 2016 Author Posted January 14, 2016 I live in the UK but was trying to duplicate my PS4 setup with Xbox 1 i.e home location over Germany etc. So I guess this proves to me that xbox live at the moment is inferior to PSN.
PharmDawgg Posted January 14, 2016 Posted January 14, 2016 Xbox and Playstation don't have all the same server locations. I think Playstation has the better servers due to Playstation being the preferred system for COD right now.
talbyfish Posted January 14, 2016 Posted January 14, 2016 xbox one UK servers show up in USAon the map, they did on AW aswell. Force p2p if you have a supa dupa connection its the best way to play.
Welshy Posted January 15, 2016 Author Posted January 15, 2016 Unfortunately I'm on dsl so not sure about the best connection. One question, how does lag comp affect a good connection on bo3?
Administrators Netduma Fraser Posted January 15, 2016 Administrators Posted January 15, 2016 xbox one UK servers show up in USAon the map, they did on AW aswell. Force p2p if you have a supa dupa connection its the best way to play. They should appear in the UK. I also did a cloud update yesterday which should help with that.
