markbrooklyn Posted January 9, 2016 Share Posted January 9, 2016 Hello. So this is the second day in a row that the speed has dropped on me while using the Netduma. Yesterday I noticed my speed was at 4 mbps or something crazy like that. I'm supposed to be getting 300 mbps. So i followed the instructions, unchecked the deep pocket processing and disabled the ip6 on Wan and Lan and it gave me my full speed. Now today I have the same exact issue and it's still disabled and unchecked. Any reason why this is happening? I know it's not my provider. They recently upgraded the nodes in my neighborhood so my connection was always over 200 mbps at anytime during the day. This is pretty frustrating. Do i have to keep changing settings or something? Link to comment Share on other sites More sharing options...
willywonka Posted January 9, 2016 Share Posted January 9, 2016 Same thing here R1 http://www.speedtest.net/my-result/4980999873 Without R1 Link to comment Share on other sites More sharing options...
willywonka Posted January 9, 2016 Share Posted January 9, 2016 powered down the R1 while using the netgear. Tried it again after it had sat an hour and speeds are back up again. This is NOT my ISP I just don't get it. I swear this thing is either being attacked, remote controlled or broken. Literally I have spent more time troubleshooting issues than I have been gaming. Feels pretty pointless right about now. Link to comment Share on other sites More sharing options...
Netduma Staff Netduma Crossy Posted January 9, 2016 Netduma Staff Share Posted January 9, 2016 Hello. So this is the second day in a row that the speed has dropped on me while using the Netduma. Yesterday I noticed my speed was at 4 mbps or something crazy like that. I'm supposed to be getting 300 mbps. So i followed the instructions, unchecked the deep pocket processing and disabled the ip6 on Wan and Lan and it gave me my full speed. Now today I have the same exact issue and it's still disabled and unchecked. Any reason why this is happening? I know it's not my provider. They recently upgraded the nodes in my neighborhood so my connection was always over 200 mbps at anytime during the day. This is pretty frustrating. Do i have to keep changing settings or something? Hey Can you press 'Reset Distribution' under device prioritisation and then not not change it anymore. Make sure you have followed all the instructions here. Same thing here Please don't thread-hijack. You have your own thread for your problems. Link to comment Share on other sites More sharing options...
markbrooklyn Posted January 11, 2016 Author Share Posted January 11, 2016 Hey Can you press 'Reset Distribution' under device prioritisation and then not not change it anymore. Make sure you have followed all the instructions here. Please don't thread-hijack. You have your own thread for your problems. Hi Crossy. Thanks for getting back. I followed all the instructions, and I'm still having the same issues. The connection on speed test shows only 14 mbps down, the upload is correct with 20 mbps. Do you know what else could be doing this? I never had this issue until i used this router. Link to comment Share on other sites More sharing options...
Netduma Staff Netduma Crossy Posted January 11, 2016 Netduma Staff Share Posted January 11, 2016 Hi Crossy. Thanks for getting back. I followed all the instructions, and I'm still having the same issues. The connection on speed test shows only 14 mbps down, the upload is correct with 20 mbps. Do you know what else could be doing this? I never had this issue until i used this router. Hey Are the congestion control sliders set to 100%? Did you press reset distribution? Link to comment Share on other sites More sharing options...
pockettown Posted January 11, 2016 Share Posted January 11, 2016 I swear I'm having the same issue I got so tried of it I just disconnected my netduma router and just use my router router I played better games with my regular router in one day than I played in over a month with the netduma router got a 1 on 1 three times same shit so I just unplug it but they not going 2 say its they router they just going 2 tell you just go to the forum personally I'm freaking tried of going 2 this forum trying 2 troubleshoot and keep coming away with nothing but laggy games and slow speeds so now I'm stuck with a router that's not doing what it advertise to do LAG KILLER not for me they have no return policy so basically if u by it u stuck with it if it work for u or not Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted January 11, 2016 Administrators Share Posted January 11, 2016 I swear I'm having the same issue I got so tried of it I just disconnected my netduma router and just use my router router I played better games with my regular router in one day than I played in over a month with the netduma router got a 1 on 1 three times same shit so I just unplug it but they not going 2 say its they router they just going 2 tell you just go to the forum personally I'm freaking tried of going 2 this forum trying 2 troubleshoot and keep coming away with nothing but laggy games and slow speeds so now I'm stuck with a router that's not doing what it advertise to do LAG KILLER not for me they have no return policy so basically if u by it u stuck with it if it work for u or not We're doing a 1 on 1 tomorrow Link to comment Share on other sites More sharing options...
willywonka Posted January 13, 2016 Share Posted January 13, 2016 Hey Can you press 'Reset Distribution' under device prioritisation and then not not change it anymore. Make sure you have followed all the instructions here. Please don't thread-hijack. You have your own thread for your problems. May not be how it works in UK but... fo·rum ˈfôrəm/ noun 1. a place, meeting, or medium where ideas and views on a particular issue can be exchanged. "it will be a forum for consumers to exchange their views on medical research" synonyms: meeting, assembly, gathering, rally, conference, seminar, convention,symposium, colloquium, caucus; More Link to comment Share on other sites More sharing options...
willywonka Posted January 13, 2016 Share Posted January 13, 2016 I was just letting him know I was having a similar issue as well as are others. Link to comment Share on other sites More sharing options...
