Netduma wifi settings will not save
My netduma as of 3 days ago is inoperable. The wifi feature will not broadcast the ssid nor will the LAN work for the Ethernet cable. Will not save my information I input then click apply. It refresh and delete all information and switch back to disabled. Making my netduma paper weight. I'm on version 1.03.4. I tried updating to 1.03.5 but I get exitcode: 2
I've used google chrome and Firefox. Also enabled cookies to save the settings but nothing works. I have to use my crappy netgear gaming router now.
Try a hard reset by pressing the reset button in the small hole on the router.
When you do , you MAY not be able to connect to the LAN (192.168.88.1) so if you're unable to , try http://r1/
After you hard reset , go to your upgrade screen , go to 'advanced', remove 'keep settings' and attempt to upgrade to 1.03.5m
First of all make sure you are using Google Chrome as your browser.
Also make sure you are using the 2.4Ghz which option - not the 5Ghz wifi option as that does not work.
I've tried that numerous of times. I use google chrome as my default browser. I even factory reset my laptop. It doenst save my information I input to enable wifi.
Have you tried rebooting the router since getting the exit code 2 error?
If I can resolve the issue with my netduma saving me wifi settings I input to broadcast a wifi signal. I'll be happy camper. After I click apply it switches from enabled to disabled. Making the wifi/LAN ports inoperable. Rebooting and clicking the reset button doesn't fix the issue. I've read other similar post titled "Netduma not working" with no end results to fix the issue.
Can you come into the chat room? :) I think I saw the post you are referring to (the one you posted in?) and it is possible that was sorted via PM.
Crossy but he mentioned the chances that it will get fixed will be slim to none. He was working with another person earlier today with the same issue me. If I'm not mistaken the ended up sending the guy a new netduma r1
I saw a thread where someone said they had to get a replacement router for a similar problem and MrHaywood couldn't stick around in chat until a couple of hours. So I suggested PMing Fraser for a 1on1 might be better :)
Fraser hasn't responded yet. I tried troubleshooting my netduma last night and no luck at all. Keeps kicking out my info ; so I can enable wifi/ LAN well internet in general from this device.
