nffcbaz72 Posted January 7, 2016 Posted January 7, 2016 Hey thanks for the info -I dunno what it is there some games I go into and I'm like a god lightning fast shoot kill move on and then the next game I go into I'm like behind every one else walk round a corner shoot and I die instant but the ping shows as 50-6p the same as the game before -when I watch the cam it shows me walking round the corner and I'm there for a Lil bit I dunno wether I'm expecting to much from this product or wethere it's just not set up right for meExactly what I have noticed, same lobby too. Have you also noticed (game related only) how different 2nd half of games is??? If you have ghosts or aw, try it, its much better. Bops3 is so bad sometimes, unfortunately the router can't do anything about it.
nffcbaz72 Posted January 7, 2016 Posted January 7, 2016 Not by much Fraser. But as stated , it is bops3 net coding I believe. But it was still nice to have someone go through settings, for piece of mind. Thank you.
sm1th1 Posted January 7, 2016 Author Posted January 7, 2016 What ping do you usually get to the host? netduma says 38-45 , bo3 goes mad betweeen 35 and 60
sm1th1 Posted January 7, 2016 Author Posted January 7, 2016 also so i bought the netduma for bo3 so i wasted my money think they need to put this in the discription as its quite a big LIE will not help kin bo3 but if you got call of duty from 4 year a go then it will work wounders
JConnor Posted January 7, 2016 Posted January 7, 2016 also so i bought the netduma for bo3 so i wasted my money think they need to put this in the discription as its quite a big LIE will not help kin bo3 but if you got call of duty from 4 year a go then it will work wounders The Netduma can't help with the following: -Bad ISP / Speeds -Bad internet routing -Low player population (XB1) -Bad servers (XB1) -Activision MM that allows anybody from anywhere to connect to the server -Badly coded game that relies on randomness and rewards high ping players instead of punish them -Lack of skill (aim, map awareness, etc). It does what it says it does if you know how to set it up: It allows console users to pick the servers / hosts they play on to reduce... Not get rid of entirely... Latency aka Lag. Having this option is worth the price of the router alone, IMO since console games don't trust the average player to know what latency is let alone how it effects their game.
Administrators Netduma Fraser Posted January 7, 2016 Administrators Posted January 7, 2016 tonight i have unplugged the netduma its pure bot awful one shot kill its like iv been given a pistol and everyone around me is using locust sniper rifles controllers have been thrown and words have been spoken , there must be a easier way to get this so called ledgendary lag free router to work to how it should with minimal fuss from me . i have follwed every guide and tryed everything even what you suggested its literally stressing me out so bad and i say summit and some one says it bo servers its misstaken servers . You're more than welcome to PM me to setup a 1 on 1. netduma says 38-45 , bo3 goes mad betweeen 35 and 60 That is not too bad. What is your base ping? We don't know exactly how they measure ping, we suspect they add processing delay. also so i bought the netduma for bo3 so i wasted my money think they need to put this in the discription as its quite a big LIE will not help kin bo3 but if you got call of duty from 4 year a go then it will work wounders It does work for BO3 as it does with most people. When AW was out people were saying how awful it is and 'even duma' can't help. Now apparently it plays great. I'm sure in a years time people will be saying the same thing only with BO3. As I said you can PM me for a 1 on 1 and I can take a look
sm1th1 Posted January 7, 2016 Author Posted January 7, 2016 when can we do this one 2 one and what does it involve
secretface Posted January 7, 2016 Posted January 7, 2016 I still have not got it to work with BO3 but I know it works for some. And yes the jitter is gone but still plays the same.
A7Legit Posted January 8, 2016 Posted January 8, 2016 also so i bought the netduma for bo3 so i wasted my money think they need to put this in the discription as its quite a big LIE will not help kin bo3 but if you got call of duty from 4 year a go then it will work woundersIt helps me. https://twitter.com/A7Legit/status/685097284392976384 You just need to know how to use it, with the right mindset every game is more fun with a Netduma R1.
JConnor Posted January 8, 2016 Posted January 8, 2016 I still have not got it to work with BO3 but I know it works for some. And yes the jitter is gone but still plays the same. Honestly, it's the game. It's particularly bad on XB1, in my experience. They keep pushing out little updates almost daily and while that may seem unheard of from a big AAA company, most of the updates break one thing while not even fixing another. Also, subjective things keep getting changed like gun balance. One day one weapon is good, the next it's trash. I'm not talking about OP weapons. I mean, normal weapons like the the Razorback, ICR-1, etc. I can't play a game like this when the weapon stats change every single day almost. There is no consistency which is ironic because that is what needs to happen for Treyarch to fix the netcode if they are serious about optimizing connections on their end.
Administrators Netduma Fraser Posted January 8, 2016 Administrators Posted January 8, 2016 when can we do this one 2 one and what does it involve You'll need to PM me and we can schedule one for when we're both available. I still have not got it to work with BO3 but I know it works for some. And yes the jitter is gone but still plays the same. Whats your average ping to the host?
secretface Posted January 8, 2016 Posted January 8, 2016 Honestly, it's the game. It's particularly bad on XB1, in my experience. They keep pushing out little updates almost daily and while that may seem unheard of from a big AAA company, most of the updates break one thing while not even fixing another. Also, subjective things keep getting changed like gun balance. One day one weapon is good, the next it's trash. I'm not talking about OP weapons. I mean, normal weapons like the the Razorback, ICR-1, etc. I can't play a game like this when the weapon stats change every single day almost. There is no consistency which is ironic because that is what needs to happen for Treyarch to fix the netcode if they are serious about optimizing connections on their end. I believe you are correct in this.
secretface Posted January 8, 2016 Posted January 8, 2016 You'll need to PM me and we can schedule one for when we're both available. Whats your average ping to the host? If I play alone it is 20 to 30 average depends on the server. If I play with my friends from the other coast its over 100ms but it plays the same about every 15th game the plays great then 15 more of hit markers and instamelts. It is anoying. My ping to host seems to make no difference.
