Need help setting up with plusnet fibre.
Hi, I can't seem to connect to the internet. I've got the netduma plugged into the BT openreach modem and have tried following the instructions in this thread:
http://forum.netduma.com/topic/7056-how-to-conect-r1-to-plusnet/
Unfortunately I still cannot connect. I'm not getting a WAN IP and it also says at the top 'interface not connected' or something like that.  Any help is appreciated.
Thanks,
Joshua.
I'm with PlusNet also. Set my R1 up today. All I had to do was enter my plusnet username and password in the WAN PPPOE menu settings and reboot the R1. To do this you will also need to ensure your BT modem is plugged in the R1 and powered on.
That did the trick, thank you very much   :D
Guest
