Problem with wifi connection after recent update.
Hi and welcome to the forum :)
What kind of problem are you having? Do your devices not connect or is it slow? Can you please be a bit more specific on what issue you are having.
- Tom
Did you reset ? if so the default wifi password is netdumar1.
If not un-tick the WiFi workaround in misc settings.
Thanks everyone for the input.
Tom I am slow over wifi. I have unchecked the workaround and reset the netduma then rechecked wifi workaround and reset and I still seem to have connection issues. I only use wifi for my phones and my wireless printer. So it's not a huge deal, but I'd like to keep the R1 as the main wifi so I can control usage while I game. (Obviously lol)
Yeah I am under 40 over wifi on my phone. I'm jailbroken so I have wifi analyzer. It shows another connection running right along with me. So I should change my R1 from channel 7 or whatever I'm on to say 9?
Channels overlap so say 5 touches 4 and 6.
I would move it to the lest populated and even better if there is a channel that has no bleed from other channels :)
Sorry! I've been busy lately! Hope everyone had a happy holiday weekend! I'm still having issues over wifi. I changed channels on the Duma and I'm still having slow connection. It's better now, but still hit bumps in the road at least twice a day. Ideas??
How many wireless devices do you have connected to the R1 ?
Is the R1 next or close to any cordless phones ? They can sometimes cause problems
- Tom
What speeds are you actually getting through Wifi?  :)
Tom, I have the router right next to my PS4 with 4 wireless devices running off of wifi. My two cellphones a wireless printer and occasionally a friends phone. Other than that the Duma is away from everything.
Hi if those are the only things using your phone how do you know the bandiwidth is low? All of those devices have very inaccurage speed tests. I'd recommend using/boring a laptop and trying out the speed :)
Only reason I know it ha something to do with the Duma is because I'll have no connection while trying to watch videos or update a post like this. But when I switch from the netduma wifi to my actual wifi I have no issue at all downloading, posting, or streaming videos.
Erm can you make sure on "Congestion Control" you reset distribution and don't touch the flower thing then have anti-flood set to 100%. Does the problem go away?
Also make sure the wifi on the other router is disabled when you're using the Netduma wifi as they may interfere with each other.
