BO3 Dedicated Servers Problem - Help
HXP
Hey there. I have discovered a major problem with the Black Ops 3 dedicated servers on Xbox One. When I play on the PS4 I have dedicated Servers in Germany which is 131km near to my house, that give me 30ms Ping. I know it is dedicated Server because I cannot rate it or update it. The other reason is that it is always there. This cant be a player host. And there is also one dedicated Server in Denmark which is near to germany. And some others near my location too. Now to the problem, on the Xbox one they dont show up. The nearest dedicated Server I do see on the Xbox One is in UK which is far away from me and it also does not give me a good ping. My Netduma settings are like this = Geofilter enabled, Radius 360 kilometers, 30ms or 0ms ping assist. Strict mode is enabled. With this settings I always get connected to my nearest dedicated server. But on the Xbox One I cant even find a game. I have to set my radius to 1500 km and pings assist to 50ms to find a game. I dont know but I think it is impossible that nobody in Germany or Belgium or Denmark or Netherlands is playing Black Ops 3 on the XBox One inside my 350 km to 500 km radius. I think there is something wrong with the Cloud Files for the Xbox One server location. Or maybe for the Xbox One these servers are not activated. Whatever I have tried so many settings for the Xbox One and the Netduma. I just cant find a game if I dont go for higher than 50ms but this makes it unplayable for me. I get connected all the time to USA or UK players which have a better ping than me. And it is always shoot first and die first for me. They are unkillable. I just cant get a decent kill with this connection. This is why I have stopped Xbox One and switched to my PS4. On the PS4 everything works like it should be. No problems. But I wish there would be a solution for the Xbox One aswell.
Any tips and tricks or any knowledge would be appreciated.
Thank you
But when I add home location to uk, nothing changes. The dedicated Servers in Germany and Denmark still dont show up. And I get connected to the UK dedicated Servers which happens now too, without changing my home location. Maybe Microsoft or Treyarch disabled them.. I dont know. Even if I change my home to UK, I get bad pings then
You could try putting your home location in the see and just using ping assist to filter games.
Ok I will try this ! I will put it into the sea near Germany and see what happens.
And the other thing is. When you first start up Black Ops 3 you get connected to all of the Servers on the World or I mean you can see them all light up for a short moment of time. But on the Xbox One I dont see the Germany and Denmark one. This is weird. I think they are shut down.
not all of them show at start screen fyi
Ok but on the PS4 I see more than on the Xbox.
And on the PS4 I get connected to them and on the Xbox not.
So what does this mean ?
Just throwing this out there but I don't believe the PS4 and Xbox use the same servers. For example PS has a server in Atlanta but Xbox does not. Because PS has the preference this year I think they have the better servers. Just my opinion.
True ! This is what I think too. PS4 has also more players. Thats why they have more servers maybe. But I think I have seen in a youtube Video The Xbox One Servers.
