MauriASR Posted December 15, 2015 Posted December 15, 2015 hi i have some issue with my netduma when i play call of duty black ops on my xbox one. i send you some pics that describes my settings and show you that i can’t find people into my geo filter zone, i also try to activate the strict mode but nothing change. This approach does not work well with destiny tnx for you time Maurizio
Administrators Netduma Fraser Posted December 15, 2015 Administrators Posted December 15, 2015 If the problem is that you can't see anything on the map please follow http://wiki.netduma.com/doku.php?id=why_can_t_i_see_anything_on_the_geofilter For Destiny, strict off and make sure auto&bleeding edge cloud is ticked and applied in settings > miscellaneous
MauriASR Posted December 15, 2015 Author Posted December 15, 2015 If the problem is that you can't see anything on the map please follow http://wiki.netduma.com/doku.php?id=why_can_t_i_see_anything_on_the_geofilter For Destiny, strict off and make sure auto&bleeding edge cloud is ticked and applied in settings > miscellaneous Sorry i forgot the pics... As you can see i can't find players in my country.
NEXTGEN NEMESIS Posted December 15, 2015 Posted December 15, 2015 How come your dots are green and mine are red?
PharmDawgg Posted December 15, 2015 Posted December 15, 2015 That just depends on which slot you have a device assigned to.
Administrators Netduma Fraser Posted December 15, 2015 Administrators Posted December 15, 2015 It looks like you've got a dedicated server within your radius which is good. If you're on a dedicated server it won't necessarily show you the players but may be potential hosts
MauriASR Posted December 15, 2015 Author Posted December 15, 2015 Ok, can you please tell me how you know that i'm in dedicate server? Tnx
MauriASR Posted December 15, 2015 Author Posted December 15, 2015 Fraser you think my settings are good??? Tnx
boxone Posted December 30, 2015 Posted December 30, 2015 Ok, can you please tell me how you know that i'm in dedicate server? Tnx Usually when you click on the dots it has Update to rate. The dots with out Update and you can't rate are usually dedicated servers I believe.
Administrators Netduma Fraser Posted December 31, 2015 Administrators Posted December 31, 2015 Sorry for the late response, I can't specifically tell from that photo or not but I imagine it is, you could test this by doing what Box said above. You settings look good the only things I would suggest is turn off upnp forwarding if the duma is in isp hub DMZ, your radius could be put to about ~1000km and you could experiment with strict mode on as well
