dominican_3niz Posted December 12, 2015 Posted December 12, 2015 hello everyone,sorry about my English im latin.. 1.do a speed test on your computer if you have one 2. you going to need the ping that you internet is best on it. 3.on your Ping Assist you going to put the same one you getting on the speedtest 4.place your home location away from any dedicate service just like the picture. 5.if you cant find any game cuz of your ping, and on your screen show you theOutside filter range host just allow that host and you will jump into a lobby with the same ping you best connection is.. for me is work no lag best hit detention ever.. thanks you i try my best English hope is work for you guys have a nice gaming bey.... http://www.speedtest.net/my-result/4908652983
lefteris.lydios Posted December 12, 2015 Posted December 12, 2015 pls explain step 5. The minute you see exclamation mark outside radius, you hit allow on it and you're in? Didn't quite understand .
dominican_3niz Posted December 12, 2015 Author Posted December 12, 2015 pls explain step 5. The minute you see exclamation mark outside radius, you hit allow on it and you're in? Didn't quite understand . yes... sometime you jump into they lobby. and i dont get host, but my hit detention is on point and no lag because of the ping assist
lefteris.lydios Posted December 12, 2015 Posted December 12, 2015 yes... sometime you jump into they lobby. and i dont get host, but my hit detention is on point and no lag because of the ping assist Thx mate, i'll definitely give it a try.
gkontos10 Posted December 13, 2015 Posted December 13, 2015 Try use PA 0 Strict On Bleeding edge Untick And its working again... P. S. Seriously now, what does bleeding edge do??
Jman Posted December 13, 2015 Posted December 13, 2015 Try use PA 0 Strict On Bleeding edge Untick And its working again... P. S. Seriously now, what does bleeding edge do?? It gives you the most recent cloud updates
Cajun72 Posted December 14, 2015 Posted December 14, 2015 hello everyone,sorry about my English im latin.. 1.do a speed test on your computer if you have one 2. you going to need the ping that you internet is best on it. 3.on your Ping Assist you going to put the same one you getting on the speedtest 4.place your home location away from any dedicate service just like the picture. 5.if you cant find any game cuz of your ping, and on your screen show you theOutside filter range host just allow that host and you will jump into a lobby with the same ping you best connection is.. for me is work no lag best hit detention ever.. thanks you i try my best English hope is work for you guys have a nice gaming bey.... http://www.speedtest.net/my-result/4908652983 So do you genuinely feel that every time we connect to a dedicated server it's bad news because the hit detection is poor compared to joining a P2P host? Anyway, thanks for the tip I'll try that out later. Ok so Last night I tried this and first few games felt smooth then... I started getting dedi servers, I could tell as there was an 'e' at the end of the number id on the screen. Should the ping assist be '0' as having a ping assist of 30ms will still connect me to dedi servers if outside radius?
Alex49H Posted December 14, 2015 Posted December 14, 2015 hello everyone,sorry about my English im latin.. 1.do a speed test on your computer if you have one 2. you going to need the ping that you internet is best on it. 3.on your Ping Assist you going to put the same one you getting on the speedtest 4.place your home location away from any dedicate service just like the picture. 5.if you cant find any game cuz of your ping, and on your screen show you theOutside filter range host just allow that host and you will jump into a lobby with the same ping you best connection is.. for me is work no lag best hit detention ever.. thanks you i try my best English hope is work for you guys have a nice gaming bey.... http://www.speedtest.net/my-result/4908652983 Gracias amigo!
