Beerbot Posted December 3, 2015 Posted December 3, 2015 Hey guys new to the forums, Havent had a problem with the router in any other game but for some reason when i play fifa 16 i never can find an opponent. Ive tried disabling geo-filter and opening my ports for xbox1. I'm not sure if anyone else has this problem but my one friend said that when he uses his Duma he cant play on madden. Any help or advice would be great.
Ste Posted December 3, 2015 Posted December 3, 2015 same problem, since the xbox 1 dash board up date.
Administrators Netduma Fraser Posted December 4, 2015 Administrators Posted December 4, 2015 Hey welcome to the forum! If you disable the Geo-filter are you still having trouble finding a game?
SaltyMcSalty Posted December 4, 2015 Posted December 4, 2015 I'm in the U.K and have no issues finding opponents with GF on and radius of 1000km, strict enabled also. If I can help with any settings I'm running just ask. Also if anyone wants to add me and discuss on Xbox just message me. GT MoobsLikeJabb4.
Beerbot Posted December 5, 2015 Author Posted December 5, 2015 i tried putting the geo filter at max range settings and that did not work. I tried disabling the geo filter and nothing changes. I even tried playing against my friends in an online friendly and it wont let me join them. I opened the ports using port forwarding and it still isnt helping. Im not sure what else to try or if it is just a problem with the EA servers. Thanks for the replys and ill message you moobs and try to see if that helps! I live on the east coast US btw
SaltyMcSalty Posted December 5, 2015 Posted December 5, 2015 i tried putting the geo filter at max range settings and that did not work. I tried disabling the geo filter and nothing changes. I even tried playing against my friends in an online friendly and it wont let me join them. I opened the ports using port forwarding and it still isnt helping. Im not sure what else to try or if it is just a problem with the EA servers. Thanks for the replys and ill message you moobs and try to see if that helps! I live on the east coast US btw I have a spare half hour now if you want to hit me up?
Beerbot Posted December 5, 2015 Author Posted December 5, 2015 I have a spare half hour now if you want to hit me up? Alright ill add you i dont have an xbox mic though
SaltyMcSalty Posted December 5, 2015 Posted December 5, 2015 Alright ill add you i dont have an xbox mic though No mic? Kinect? Not sure I'll be any more help on Xbox than I am on here to be fair without being able to talk to you.
Beerbot Posted December 5, 2015 Author Posted December 5, 2015 yeah i have been using skype to play on xbox since my mic was meant for the 360
Administrators Netduma Fraser Posted December 5, 2015 Administrators Posted December 5, 2015 If it doesn't work with Geo off it is just acting like a normal router. Check your NAT as that may be causing an issue
Beerbot Posted December 6, 2015 Author Posted December 6, 2015 If it doesn't work with Geo off it is just acting like a normal router. Check your NAT as that may be causing an issue Okay i checked my NAT and its all open every other game works fine which is why i think it may be something to do with EA and not my router
