Help very low speeds
Ok so ive been having problems getting into games..still outside geo games too.so decided to check all settings and run a speed test.
I pay for 152 down 12 up. my setup is modem ...netduma ...switch...switch..xbox 1 everything on my network is hard wired exept for mobiles and ipads.
Ran speed test using ethernet from xbox..(7 down 3 up.) a wtf moment..congestion control 100% to xbox..sliders 100%..ran test 6 times same results.
Then ran same tests connected directly to the duma..same results...
Then directly to the modem..getting over what i pay for. WTF is happening here. Assume i have the latest firmware and I have followed your settings to the letter.
Please help
1. Click the selections below the prioritization flower- the reset and the update even though is says everything is evenly spaced.
2. Move the sliders back and forth( both of them) and set them at 100%
3. Make sure your bandwidth is set correctly in the set bandwidth boxes
4 Turn off all IPv6 items- WAN/LAN and unselect the one under settings>miscellaneous
5. Make sure you are on reactive
6. Unselect deep packet processing
7. Select the first turbo mode (not the second one)
8 Reboot router and wait a few minutes and try the test again wired.
Let us know the results. Good luck.
like i said in my post everything is set by your instructions..done everything above.. now what
Trust me when I say their going to basiclly go through what I just suggested. Only other options 1. Reboot or 2. Factory Reset
Speed test are being conducted wired as well?
the reason I ask for a 1 on 1 is so you can check my settings..just to prove to you they are correct and I am still not getting the speeds I should.
i have rebooted..the only thing I havent done is a factory reset..
Maybe you did not reset the device priority flower.
It now does download as well as upload priority so it will throttle other devices.
well all done now..thx for the support..just one more question I am still getting the odd game outside the geo..mainly the states why?
Have you changed the service to xbox live or playstation network and not the PA versions from the old firmware?
You need to say if you have changed the service or not.
It has to be changed so not to connect outside the geo.
Yes i have xbox live not pa and yes i am still connecting now and again to us server will post pics when i get home from work..thx
Do you have strict mode ticked?
When you connect to said server could you click on it and ping it please and tell us what ping it shows thanks.
Yes strict is ticked..traced it went west coast US then mid US..will let u know ping tonight..if I connect with it again
The trace can be very inaccurate, the ping will be great if you can tonight.
If it is a low ping and showing US could you post the ID.
