I need some help please
kinel
around 11ms cheers
You are defo on fast path then no need to buy a modem unless you want one.
Cheers zennon  i thought i might have been on fastpath but i wasnt sure
you have been grate help  thanks again
zennon i just wanted to ask you one more question on the Hauwei hg 635 super router and g inp.
i recently done a factory reset on the Hauwei hg 635 super router and i toticed the pings stay the same always around 11 ms.
this is in either in the router mode or bridged mode theres no diffrence in the ping
so i just wanted to ask do you think the g inp is enabled   when the router is used normal router mode
as i thought  g inp was enabled in modem mode or bridged mode
i hope i made sence
G.inp is set in the cabinet, it is whether a modem or router has compatible firmware to accept it.
Yours does so will work in either mode.
11ms ping is very good :)
Thank you :)
I will close the thread now any more questions just make a new post pm me or hang out in chat :)
