no ping and outside geo and still lag
secretface
something else I have noticed which I never had before but the aim assist is locking in off target. I'm guessing this is some kind of lag as well.
never loads on bout half the games
Well the joining outside of GeoFilter should be fixed later on in a new update :) When it just keeps loading the ping, if you right click the page, press inspect element and then click the console, are there any errors? :)
Im not seeing an error there, at the top says there is one error but cant seem to find it
Try giving the router a reboot and see if that works :)
ok though I have rebooted several times trying to get the other issues worked out. cant hurt to try again
Hard reboot your console too. That seems to help as well.
Ill have to look into the stuff in that link but weird that it was working and now stopped.
it works at the very beginning and end of matches but not during. Sometimes will work. just weird.
If you follow everything from that link it should help you be able to ping. Host outside the radius fix is incoming , we're working on it
ok different pc's different operating systems still same ping thing
If when you get the ping problem, you right click the page and click 'inspect element' then click 'console', do any errors show?
