PS4 lan cable not connected
I have this issue too. It happens maybe once every 5-6 hours of play (ps4 connected by cable)
It kicks me out of the game I'm playing, but the connection is always back up quickly.
Also the wifi drops fairly often (maybe the same frequency, hard to know), coming back up instantly but requiring a prompt on Netflix to start again
FYI: This is a SonyPlaystation issue. If you Google this issue you will see many people having the same error message pop up. There has been no resolution yet. I would probably contact Sony.
Try using a different cable, I different port on the Netduma and also make sure the cables are plugged in all the way and aren't loose :)
