Silent Posted September 9, 2015 Posted September 9, 2015 I usually get 110 download and around 20 upload and for some reason im only getting 17 and 12. i have all the correct settings for 110+ and also my congestion is 100 percent. Could it just be my internet messing up?
PharmDawgg Posted September 9, 2015 Posted September 9, 2015 Just double check: 1. You have the correct speed entered into set bandwidth and may that they are not flipped 2. After that click reset distribution and update distribution 3. Go to Setting>LAN and make sure IPv6 is unselected then press apply 4. Go to Setting>WAN and make sure IPv6 unselected then press apply 5. Go to Setting>Unselect Link-local IPv6 6. Go to Congestion Control and make sure Reactive is selected Reboot router then check your speeds one more time for us.
Administrators Netduma Fraser Posted September 9, 2015 Administrators Posted September 9, 2015 Also in settings > miscellaneous ensure deep packet processing is off
