Best settings for smoothest connection
Chive972
I forgot to add the 8. I will later today on my Netgear router. But is it ok to do it on the R1 under the WAN section?
You could do it in WAN yes would be good to do the same in LAN as well :)
First disable both in LAN and WAN and then enter 1480 in both and apply? I did that yesterday but after it said Radio disabled so I am not sure if it took or not. Should probably reboot the r1?
Mine was on automatic but I changed it to 1480. I haven't tested it out in gameplay yet though to see if I notice any difference.
If you go back to the page and its still applied then yeah should be okay :)
