HELP
KCINCO
Just tried a difrent cable to PC but not change the cable modem to netduma. Im gonna do it later... And try connecting without bridge Mode. I Will five news soon. Thanks for the support
Correct speeds in congestion control...
When you say router make its thr brand/Mark of the router?? I dont understaind.... Make/do/does
Its a zon hub 3.0
I don't think that is an affected modem. When you have time can you try the modem not in bridge mode and see if that makes a difference :)
I did the test without bridge Mode and its good... Gives me best connection
Ok, so maybe you could leave it like that and out the Netduma in the DMZ? Doing that shouldn't make any performance differences apart from increase the speeds as bridge mode seams to be lowering them with the Netduma connected.
Lol i didnt change nothing... I came back put it out of bridge restart did the test put it in bridge restart did the test again and now it came back to normal...
So it's all good now? :)
Thanks a lot... Its fine... Finally got my connection with bridge in netduma... But didnt change anything...Maybe it was in holydays for a few hours...
End of the post...
Netduma working fine
End of the post...
Thats good news - as its sorted I'll close the thread :) Feel free to open another one if it happens again and you can't sort it out.
