blue water Posted July 10 Posted July 10 Hello I'm needing some help with my netduma r3 I accidentally turned gio fence on during a loading screen right before the match started in dbd and then I turned it off I accidentally turned it back on then off again I was trying to hit the back button I then left the game because I didn't want my connection to be messed up due to gio latency filter being turned on after that I then went to xbox dashboard and then i deleted the device from the gio filter then I did a resinq then added the device back and then rebooted the router just in case any problems that may have been caused due to gio latency being turned on and off rapidly after that I have noticed my ping assist is not working correctly and also I have noticed that the netduma keeps trying to connect to a blocked server and it won't stop
blue water Posted July 10 Author Posted July 10 Also I'm not using the private beta so maybe if I flash the router with the private beta it could solve this issue I'm currently running the firmware version v.4.0.540
Administrators Netduma Fraser Posted July 11 Administrators Posted July 11 I've given you Early Access so you can upgrade to that version: https://forum.netduma.com/topic/60946-new-r3-firmware-dumaos-401147/ Then see if it works normally.
blue water Posted July 11 Author Posted July 11 I don't have a pc can u walk me threw upgrading firmware on my phone and thank u so much fraser for the help I truly appreciate u and the other people that make these routers possible also I have another question do I need to remove my device from gio filter before upgrading to new firmware and do I have to factory reset after upgrade is complete
Administrators Netduma Fraser Posted July 12 Administrators Posted July 12 Download the firmware on your phone, access the interface via your phone, go to Settings > Troubleshooting > Upload firmware > Select the downloaded firmware You don't need to remove the device from the Geo-Filter and you don't have to factory reset after the update.
