buzz Posted Saturday at 04:44 PM Posted Saturday at 04:44 PM Hi, I am writing to ask for assistance in understanding an ongoing issue with my home broadband setup. I am currently on a 500 Mb Virgin Media broadband package. When I run a speed test directly through the Virgin Media router, I consistently receive speeds close to what I am paying for — around 470–500 Mb download and 50 Mb upload. However, when I run the same speed test through my Netduma R3 router, the download speed often drops dramatically to around 60–80 Mb, while the upload speed remains normal. This issue has happened several times. On previous occasions, resetting the Netduma R3 temporarily restored the correct speeds, but the problem keeps returning. I have changed some settings as I am getting owned on Black Ops 7 🤣🤣 so I am unsure if I have done something making the Netduma R3 limiting the speed. I would appreciate guidance on what might be causing this and how to prevent the speed from dropping in the future. Thank you for your time and support. Kind regards, Pete
Krush Posted Saturday at 05:32 PM Posted Saturday at 05:32 PM Salut ! Tes tests de vitesse sont faits via l'outils Netduma ou derrière un PC en filaire via ookla ? L'outils Netduma utilise parfois des serveurs de test de vitesse non optimisé, le mieux est de rentrer manuellement les vitesses max données par ton FAI ! buzz 1
Administrators Netduma Fraser Posted Saturday at 06:16 PM Administrators Posted Saturday at 06:16 PM As above, do the speed test on speedtest.net, do you get your expected speeds then? buzz 1
buzz Posted Saturday at 07:18 PM Author Posted Saturday at 07:18 PM Hi Krush and Fraser thank you both for replying . This is what I got earlier but can try Speedtest aswell. Krush 1
Administrators Netduma Fraser Posted Saturday at 07:37 PM Administrators Posted Saturday at 07:37 PM Okay that's good then, the router isn't limiting you, it's just the speed test provider the router uses isn't always the most accurate so you can ignore that Krush and buzz 2
buzz Posted Saturday at 07:55 PM Author Posted Saturday at 07:55 PM Okay thanks Fraser so all good with the Netduma R3 I was concerned trying to bring latency down for gaming I have made mistakes with Netduma settings .Playing between 26ms and 31ms latency but other gamers are saying they are 16ms so I believe they are closer to the server if that’s right . Krush 1
Krush Posted Saturday at 08:23 PM Posted Saturday at 08:23 PM Oui c'est ça ! Vous jouez en équipe ? En fonction de la proximité du serveur la latence n'est pas la même entre les membres d'un groupe de jeu ! Le jeu utilise des serveurs dédiés, l'hôte n'est plus le relais comme avant sur du serveur P2P ! buzz 1
buzz Posted Saturday at 08:49 PM Author Posted Saturday at 08:49 PM Hi Krush, I am playing on my own. Totally understand thanks again Pete Krush 1
Administrators Netduma Fraser Posted Saturday at 09:06 PM Administrators Posted Saturday at 09:06 PM 1 hour ago, buzz said: Okay thanks Fraser so all good with the Netduma R3 I was concerned trying to bring latency down for gaming I have made mistakes with Netduma settings .Playing between 26ms and 31ms latency but other gamers are saying they are 16ms so I believe they are closer to the server if that’s right . As mentioned, people will be closer/further away to the server so that will impact it. Given you're in Scotland your closest server for any game is almost certainly in London. Then your location, for example if you're in a major city or the highlands would impact it as well. Also just the general routing your ISP takes to the game servers. Essentially, there are so many variables to consider that you can't really compare your network experience to anyone else - I'd even go so far as saying not to compare to your neighbour as even then the quality of the cables feeding your houses can impact it, the amount of devices being actively used at a time etc. buzz 1
buzz Posted Saturday at 10:23 PM Author Posted Saturday at 10:23 PM Thanks Fraser Netduma Fraser and Krush 2
