On 8/14/2025 at 10:40 AM, Netduma Fraser said:
See if you can access this page: http://192.168.77.1/dumaweb#!/support to re-upgrade the firmware and see if it works better then.
This worked thanks alot! Went back to 540, you might want to look at factory reset on beta firmware 645. Congestion control on older firmware I can set it to 70% and get good bufferbloat on 645 I have to bring it down to 50%.
Glad to hear that, thanks will do. Different firmware may require slightly different settings to achieve the same effect due to things changing in the backend. With our next big feature it will improve QoS overall
