qakos Posted May 31 Posted May 31 Hello, I'm experiencing a persistent networking issue that severely affects my gaming experience. I've recorded a video demonstrating the problem: 🔗 In the video, you can clearly see the abnormal behavior — it feels like hit registration and responsiveness are completely off, even though my connection appears stable. I've already tried multiple solutions, including router configuration, port forwarding, prioritizing traffic, and even using different ISPs or network setups. I'd really appreciate it if someone with more experience could take a look and give me advice or ideas on what might be going wrong. Any suggestions or insights are welcome. Thank you in advance for your help!
Administrators Netduma Fraser Posted May 31 Administrators Posted May 31 There doesn't appear to be anything wrong with the ping, in this scenario I think it'd be best to block the server and try to force another that may play better Juju31 and qakos 2
Administrators Netduma Fraser Posted June 1 Administrators Posted June 1 Your connection stability looks fine, have you tried blocking servers you're experiencing these on and forcing others to see if they play better?
Administrators Netduma Fraser Posted June 6 Administrators Posted June 6 Your connection definitely looks very stable, try forcing other servers, even if the ping is slightly higher, that should improve your experience
dizin Posted June 11 Posted June 11 On 6/3/2025 at 9:41 AM, Burtchnasty said: The problem came back, like always. I’ve yet to find a consistent fix. Sometimes it works for a few days, sometimes a few hours. But the desync/extrapolation bullpoopy always comes back That never improve your experience in call of dutyÂ
stokoe1011 Posted September 13 Posted September 13 I Feel your Pain Brother this is What Happens when Call Of Duty a MUTI BILLION DOLLAR COMPANY Cheap out on Servers Play Battlefield 6 when it Releases at Least you will get closer to 120Hz-140Hz Servers with none of this Bull Crap and Manipulation of Connections and Strict and un Popular SBMM i Remember Playing BF4 Which came out in 2013 a Game from Over12 Year ago and that had 120HZ Servers and a Server Browser so None of this Nonsense these Video's are Just Proof of how Scummy and Greedy Activision are as they don't Want to Shell out on Decent Servers as that Would Hit them in the Pockets it's all about the $$$ with that Greedy Corp Unlike Other Publishers who Rent out Servers Like Microsoft Azure Servers Because They care about there Players Experience   Activision Don't
Burtchnasty Posted 3 hours ago Posted 3 hours ago @qakos I think i might have finally figured it out man. Assuming you've done everything on your end and run tests to make sure your not getting packet loss or any of the other more common network issues, try this: 1. Open Command Prompt (As Administrator) 2. Type these two lines individually: 1. bcdedit /set disabledynamictick yes (Press enter) 2. bcdedit /set useplatformclock yes (Press enter) This basically forces a single, consistent "platform clock" for all timing decisions (Operating system, network packets, CPU scheduling etc) to be synchronized. This in turn, reduces tiny micro-jitters that i think CoD is highly sensitive to that ends up causing a ton of desync and extrapolation. Both of those issues happen server-side and are triggered when updates from you -> server do not happen on time/in sequence/are jittery. I'm only a few play sessions into this, but its remained a consistent fix for longer than anything else I've ever tried over the last 6 years. Let me know how it goes for you dude!
